Inventor General Discussion
Distinguished Contributor
4 Kudos
Post 1 of 11
Hiding BOM column
347 Views, 10 Replies
09-25-2012 06:45 AM
Is it possible to have a column in the BOM but i do not want to show it on the drg.
like you can do it for rows for example...
thank,s
ric
Screen caps
Distinguished Mentor
50 Kudos
Post 2 of 11
Re: Hiding BOM column
09-25-2012 06:52 AM in reply to: richiesuk
Edit the parts list in the drawing and use the column chooser to remove the column you don't want.
John Retzlaff
4 Kudos
Post 3 of 11
09-25-2012 06:58 AM in reply to: john.retzlaff
I do want to have the column in the drawing in the bom but I do not want to show it.
50 Kudos
Post 4 of 11
09-25-2012 07:35 AM in reply to: richiesuk
Removing the column from the parts list in the drawing does not remove it from the BOM.
John Retzlaff
4 Kudos
Post 5 of 11
09-25-2012 07:54 AM in reply to: john.retzlaff
I start again :smileyhappy:
drawing environment:
I want to have a column, but do not want to show it on the drg,
but if I edit the BOM in the drg (not assy) I want to see it, so if I expot it it will be there, but if I print it it wont...
we need some extra details for purchasing porpuses ,etc...
thanks,
ric
50 Kudos
Post 6 of 11
09-25-2012 07:58 AM in reply to: richiesuk
I guess I don't understand.
John Retzlaff
269 Kudos
Post 7 of 11
09-25-2012 08:52 AM in reply to: john.retzlaff
I have the same question.  For instance, sometimes when I edit the drawing parts list, I want to be able to see the part numbers and maybe even the filenames of each item in the list.  But, I don't want either the part number or filename columns to be visible on the sheet.
It is possible to turn off the visibility of rows in a parts list, but we are wondering if it is also possible to turn off the visibility of columns.
1,708 Kudos
Post 8 of 11
09-25-2012 09:20 AM in reply to: richiesuk
Hi richiesuk,
Let's define terms first:
BOM = the table in the assembly that contains bill of materials info
Parts List = the table on the drawing that displays BOM info
With that said, I've not found a way to hide columns in a Parts List, other than using the Column Chooser to remove them.
I think the best approach is to format your parts list to show only the columns you want to show on the page, and then access the BOM editor to see and edit other columns (right click on the Parts List > Bill Of Materials).
The other trick I've used is to create an alternate parts list style that shows the columns, and then just switch the parts list to that style (select it then go to the Annotate tab > Styles pull down), then edit the parts list, then switch it back to the original style that doesn't show the "hidden" columns.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Mentor
62 Kudos
Post 9 of 11
09-25-2012 08:13 PM in reply to: Curtis_Waguespack
Hi
Simple solution, change the column width to "1".
Reg
Autodesk PDS Ultimate 2015 SP 1 Build 203
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please Give Kudo's / accept as a solution if it solves your problem.
Valued Mentor
62 Kudos
Post 10 of 11
09-25-2012 09:30 PM in reply to: rhasell
Screen caps
Reg
