Inventor Forum
Hiding BOM column
10 REPLIES 10
Message 1 of 11
richiesuk
1564 Views, 10 Replies
Hiding BOM column
Is it possible to have a column in the BOM but i do not want to show it on the drg.
like you can do it for rows for example...
thank,s
ric
10 REPLIES 10
Message 2 of 11
in reply to: richiesuk
Edit the parts list in the drawing and use the column chooser to remove the column you don't want.
Message 3 of 11
richiesuk
I do want to have the column in the drawing in the bom but I do not want to show it.
Message 4 of 11
Removing the column from the parts list in the drawing does not remove it from the BOM.
Message 5 of 11
richiesuk
I start again 🙂
drawing environment:
I want to have a column, but do not want to show it on the drg,
but if I edit the BOM in the drg (not assy) I want to see it, so if I expot it it will be there, but if I print it it wont...
we need some extra details for purchasing porpuses ,etc...
thanks,
ric
Message 6 of 11
I guess I don't understand.
Message 7 of 11
cwhetten
I have the same question.  For instance, sometimes when I edit the drawing parts list, I want to be able to see the part numbers and maybe even the filenames of each item in the list.  But, I don't want either the part number or filename columns to be visible on the sheet.
It is possible to turn off the visibility of rows in a parts list, but we are wondering if it is also possible to turn off the visibility of columns.
Message 8 of 11
Hi richiesuk,
Let's define terms first:
BOM = the table in the assembly that contains bill of materials info
Parts List = the table on the drawing that displays BOM info
With that said, I've not found a way to hide columns in a Parts List, other than using the Column Chooser to remove them.
I think the best approach is to format your parts list to show only the columns you want to show on the page, and then access the BOM editor to see and edit other columns (right click on the Parts List > Bill Of Materials).
The other trick I've used is to create an alternate parts list style that shows the columns, and then just switch the parts list to that style (select it then go to the Annotate tab > Styles pull down), then edit the parts list, then switch it back to the original style that doesn't show the "hidden" columns.
I hope this helps.
Curtis
Message 9 of 11
rhasell
in reply to: Curtis_Waguespack
Hi
Simple solution, change the column width to "1".
Reg
2024.2
Please Accept as a solution / Kudos
Message 10 of 11
rhasell
in reply to: rhasell
Screen caps
Reg
2024.2
Message 11 of 11
richiesuk
thanks guys,
this  "width= 1" did the trick
btw it should be a hide options like for the rows has
richard
Autodesk Customer Advisory Groups
