Hi all,
I have an assembly with some hidden solids of a part in, which are turned to invisible in the part but they show on the drawing.
Anyone know how to not show these in the drawing but still show the unhidden soild of the part.
Thanks in advance
Greg.
Solved by blair. Go to Solution.
I think you should take a look at View Reps. You can create an number of View-Reps within the Assembly and then use which ever View-Rep you need in your drawings with what ever items you want suppressed or visible.
When creating your Views in the drawing, you will need to select which View-Rep you want to use.
