Inventor Forum
Hidden Line Calculation
4 REPLIES 4
Clarkeng09
656 Views, 4 Replies
Hello All,
We have been having some issues with our assembly drawings not calculating hidden lines correctly.  What is happening is Visible lines are being set to hidden so when we turn the hidden lines off half the lines disappear.  I have no idea what could be causing this because it only happens to some views and to specific parts.  If I make a part drawing the lines are correct.
The attached images hopefully show what is going on.  It is also effecting multiple drawings and is not allowing us to accurately show critical information.
Any help is appreciated.
Steve
Windows 7 x64 -24 GB Ram
Intel i7-3840QM @ 2.8GHz
nVidia Quadro K5000M - 4GB
Inv 2013 SP2 Update 4
Vault Collaboration 2013 Update1
4 REPLIES 4
Hi  Clarkeng09,
Here is something to try:
  • locate the drawing view in the drawing browser
  • then expand the model tree for that view
  • then locate the components in question in the browser tree
  • then right click on that component node
Do you have the option to un-select Hidden Lines from the right click menu? If so it sounds if someone has set specific components in certain views to show hidden lines at some point in the past.
I hope this helps.
Curtis
Did Curtis's suggestion help?
Nathan Chandler
Principal Specialist
Clarkeng09
in reply to: innovatenate
Thanks for the suggestions, I looked into the hidden lines of the parts and it doesnt look like thats the issue.  I also noticed if I select top view the lines are not correct, however if I rotate slightly off top they are just fine.  Take a look a the attached files, nothing was touched in the browser or view settings only the rotation.
Steve
maulik_patel
in reply to: Clarkeng09
Hi !!!
Thank you so much for reproting the issue on this forum. Can you provide dataset you were using for more investigation?
For dataset smaller than 20MB, please send it via email (maulikr.patel@autodesk.com). For larger dataset, please send me an email so I can set up a secure account for you to upload.
Maulik R Patel (maulikr.patel@autodesk.com)
SQA Engineer, Inventor
Autodesk, Inc.
