No, Kathy I appreciate the help on the first one as well. It made sense.
I'm sorry, I didn't mean to sound like I was not appreciative.
I think both of these are bugs. Haven't heard from any Autodeskers lately..
you guys around?
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
"KJohnson" wrote in message
news:5E62DAA969A202AA03BBE8765940BDDB@in.WebX.maYIadrTaRb...
> Sorry that I could not help with the second problem.
> Kathy Johnson
> "Sean Dotson" wrote in message
> news:EE1DC554A6EE8991B6CB396CC4A6B458@in.WebX.maYIadrTaRb...
> > I'm more concerned about the second part of the problem.
> > It seems that is you assign a part two different colors via the
properties
> > method (no textures involved) only the base color shows in the ipn.
> > Sean Dotson, PE
> > news:74938ECE29A7215CE74FB8BFDF0C0D5F@in.WebX.maYIadrTaRb...
> > > Having any two colours with different textrues would propably do it.
I
> > have
> > > not installed 6 so I can't comment about a bug. Maybe someone else
can
> > try
> > > and duplicate it.
> > > Kathy Johnson
> > > news:956737B7C103E7B5785B496062DE974B@in.WebX.maYIadrTaRb...
> > > > They are As Material. Perhaps it's since I took the same color
> > > Green(flat)
> > > > and added a different texture to it in two different files?
> > > > As for the problem with a part that has two colors on it not
> displaying
> > > > properly I was incorrect before. It appears properly in the IPN but
a
> > IDW
> > > > of the IPN causes them to show in the same color. This, I'm
thinking,
> > may
> > > > be a bug..
> > > > Sean Dotson, PE
> > > > news:539E300163585B11EBAD72CD4BD4F6D9@in.WebX.maYIadrTaRb...
> > > > > My problem was that I had altered the default colour in one part
> file.
> > > > Once
> > > > > I changed the default back to the original and used a different
name
> > > > > everything worked out fine. As to the other with two colours. If
> you
> > > > > select the part in the IPN, what does the style drop down say? I
> > think
> > > it
> > > > > needs to be As Material if I remember correctly.
> > > > > Kathy Johnson
> > > > > news:458577979B13DE9167E33B8882D5CDDA@in.WebX.maYIadrTaRb...
> > > > > > I remember a while back you had a problem with the colors of
parts
> > not
> > > > > > working correctly in presentation views. I searched the support
> > group
> > > > but
> > > > > > couldn't find the right thread (probably looked right over it).
> > What
> > > > did
> > > > > > you finally find out about this? The reason I ask is that I'm
> > seeing
> > > it
> > > > > in
> > > > > > R6 as well. A part that has two colors on it is coming through
as
> > one
> > > > > solid
> > > > > > color. Also textures that are different on two different parts
> are
> > > > > showing
> > > > > > as the same texture in the IPN. Figured I'd go straight to the
> > > > > > "presentation queen"
> > > > > > Thanks,
> > > > > > Sean Dotson, PE
