Inventor Forum
Help with the Sweep Function!
4 REPLIES 4
Boudy25
980 Views, 4 Replies
Here it is gents i need help with a simple task thats ruining my life. I have two faces of different size and am trying to sweep out a curve section between the two. But since the two faces are of different size it only follows the path with the original face selected.
4 REPLIES 4
JDMather
in reply to: Boudy25
Maybe sweep with guide curve or surface.
Attach the *.ipt file here.
If not Sweep, then Loft.
http://forums.autodesk.com/t5/Inventor-Engineer-to-Order/HELP-Problems-with-Sweep-Function/m-p/47431...
PaulMunford
Looks like a candidate for a loft to me. It's difficult to see what your inputs are. Could you upload the part?
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
glenn-chun
Hi Boudy25,
Loft is more appropriate than sweep in this case since you have two different profiles.  Before you create a loft, add a tangent constraint to your Sketch11 like this:
A loft cut using two profiles and two rails would work.  See "Electric Housing Part 2 (orig plus loft cut).ipt".
I noticed that you used 5 features (3 extrusions and 2 sweeps) when you could create the same shape with a single extrude operation.  I used the following steps in "Electric Housing Part 2 (Glenn).ipt".
1. Extrude a rectangle with a taper angle of -15.25 degrees.
2. Create a loft surface from two profiles and two rails.
3. Remove the material below the loft surface by using the Split tool.
Final result:
Hope this helps,
Glenn
Autodesk ShapeManager Development
Glenn Chun
Sr. Principal Engineer
glenn-chun
in reply to: glenn-chun
Just in case anyone is wondering how I obtained the taper angle from the given taper distance...
tan(theta) = opposite / adjacent
theta = arctan( opposite / adjacent )
tan(taperAngle) = taperDistance / extrudeDistance
taperAngle = arctan( taperDistance / extrudeDistance )
= arctan( 0.3 inch / 1.1 inch )
= 15.2551187 degrees
The minus sign is used for the taper angle since the profile size decreases as it is extruded.
An alternative for the tapered extrusion in this case is a loft between two rectangular profiles.
Glenn
Glenn Chun
