Recently I had to convert a .stl to an .ipt, to do this I converted the .stl to a .dxf and then stitched to wire together. Now I need to make a detailed drawing of the part, but the surfaces are not smooth, anyway I can fix that? All I was able to find while researching was how to smooth lofts, which this is not.
Details: Autodesk Inventor Professional 2013
(I had to delete the sticthings to make the file small enough)
Solved by JDMather. Go to Solution.
1. You did not need to convert to dxf
2. You can convert your Inventor surface model to a solid model using the Sculpt command in Inventor and selecting the surface body.
3. Rather than use an stl (faceted faces) for something this simple - I would create it over from scratch in Inventor.
Are you bu any chance designing a CO2 gas cylinder powered balsa wood F1 car?
Not balsa wood but plastic. It is planned that it will be printed on a 3D printer. To be specific a Makerbot, which is why it was in an stl format.
Do you have the original file (before it was ever saved in stl format)? *.dwg? *.dxf? *.ipt?
No, that is why I needed to convert it to a solid body. The problem is the school where I study has it so that any deleted file is directly removed, completly by-passing the recycling bin, as then there is no hopes of recovering deleted material.
Two words - Thumb Drive.
Because you are designing a CO2 car I thought you might find this interesting. Top Gear SA has a "F1 in schools challenge" and my company is part of this project. Go have a look at it, you might find it interesting: http://www.modena.co.za/news/f1-in-schools-technology-challenge/19
