Inventor Forum
Help with sheet metal part
8 REPLIES 8
Message 1 of 9
pball
861 Views, 8 Replies
I could use some help making a sheet metal part work. The part is good except for where two flanges meet and don't have a gap, which makes it impossible to get a flat pattern.
The part attached is from 2014 and I have two pictues the part also.
8 REPLIES 8
Message 2 of 9
mcgyvr
in reply to: pball
How will this part be fabricated? press brake only?
Why not just sketch the complete bottom face then add the flanges
Message 3 of 9
pball
in reply to: mcgyvr
Press brake only
Message 4 of 9
jneal
in reply to: pball
See attached. This is how i would do that piece. I did not bother to trim/fix the ends. I left all of your sketches in tact as well...
Application Engineer
All CAD Northwest
Meridian ID
Message 5 of 9
KulasekaranK
in reply to: pball
Hi,.
I am using inventor 2012 so i could not use your file,.
From the attached picture I understud that, the part doesn't have a slit to 'unfold' (as you told)
@pball wrote:
" where two flanges meet and don't have a gap,"
Make a slit before creating a flange at the meeting point,.
Message 6 of 9
pball
in reply to: jneal
Well I was looking for a way to have it with the ends like they are in my original part. I ended up after starting this thread using a method like you posted and manually fixing the ends because I needed to get the part done.
KulasekaranK
I don't quite understand what you mean, could you make an example or something?
Message 7 of 9
icouture
in reply to: pball
The easiest way to do this would be to make the bottom of the piece as a face. Once that is done, use the flange tool to make your flanges. Once the part is fabricated you'd then only need to get a welder to seal off the slits.
Message 8 of 9
pball
in reply to: icouture
That's how jneal did the part he attached and how I ended up making my part. I'm trying to see if there is a method to making this part where the ends of the flanges do not need to be fixed.
Message 9 of 9
IgorMir
in reply to: pball
Please have a look at this part. I think it answers your question about the ends of the returned flanges.
The file is in IV2010 format.
Best Regards,
Igor.
Web: www.meqc.com.au
