Hi, im having problems trying to solve how to built this duct with sheet metal. Attached its a draw with the idea.
First i thought using simple contour flange, but the change of dimensions stopped me
Anyideas?
Can you attach your *.ipt attempt here?
You are doing pretty good (but I would have used Contour Flanges rather than Lofts).
And your part fairly shouts use symmetry. Sketch1 should be symmetrical about the origin.
I'll come back later if someone else doesn't add to your present model.
