Inventor General Discussion
CAD-One
Message 1 of 13 (146 Views)
Help with Loft
146 Views, 12 Replies
08-19-2014 06:05 AM
I am trying hard to loft this. i cant understand why it would not?
Can any of you figure this out for me, please.
C1
Inventor Professional 2015
Vault Professional 2015
Hi!
Just a print screen with the result and operations.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Distinguished Mentor
ccarreiras
Message 2 of 13 (133 Views)
Re: Help with Loft
08-19-2014 06:47 AM in reply to: CAD-One
Hi!
You need a loft, but not as you are thinking, i guess.
Its better do one part and then make a circular pattern to achive all part
I dont have Inv 2013, so i 'm sending you the model in step format.
But i can explain how to do it, if you will.
Regards.
CarlosC
Autodesk Inventor 2014 Certified Professional
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
ccarreiras
Message 3 of 13 (129 Views)
Re: Help with Loft
08-19-2014 06:57 AM in reply to: ccarreiras
Hi!
Regards.
CarlosC
Windows 7 64Bit
CAD-One
Message 4 of 13 (122 Views)
Re: Help with Loft
08-19-2014 07:04 AM in reply to: ccarreiras
Mindblowing !
I was wondering if there was any error in my sketches.
Kindly expand the (+) for the loft feature. I want to know which sketched you used, please.
Again, thanks for your help Carlos.
C1
CAD-One
Message 5 of 13 (115 Views)
Re: Help with Loft
08-19-2014 07:21 AM in reply to: ccarreiras
Nevermind!
I got it, thanks again.
C1
ccarreiras
Message 6 of 13 (112 Views)
Re: Help with Loft
08-19-2014 07:23 AM in reply to: CAD-One
Hi!
It's a little moere then this.
First objective: create the surface with loft.
1 - Create a construction plane (chose the central axis and a poin of the octahedron near your "vertical" skecth2)
2 - Open sketch2 and copy the geometry
3 - Create new sketch (sketch8 in the image) and paste the geometry. Transform the copyed geometry in "block" to maintain the form intact.
project the points from both tetahedrons and conect the copyed geometry to these two projected points.
4- Now you have two sketches (your in red iand the new in blue), you can perform the loft: open the loft tool, change to surface mode and chose both sketches.
Now you have a nice surface. End of first objective.
Regards.
CarlosC
Windows 7 64Bit
Valued Mentor
Valued Mentor
wh
Message 7 of 13 (110 Views)
Betreff: Help with Loft
08-19-2014 07:28 AM in reply to: CAD-One
Here's another idea. (2013 file)
Walter
CAD-One
Message 8 of 13 (99 Views)
08-19-2014 07:45 AM in reply to: wh
WH-Thanks for showing different approach.
C1
karthur1
Message 9 of 13 (94 Views)
Re: Help with Loft
08-19-2014 07:58 AM in reply to: CAD-One
And yet a simplier approach.  I am using 2015, but here is a video of how I did it.
http://screencast.com/t/ElkjjApoNz
Kirk
CAD-One
Message 10 of 13 (72 Views)
Re: Help with Loft
08-19-2014 08:51 AM in reply to: karthur1
Art - I should say its nice & simple with out involving surfacing tools. Thanks.
C1
