I am trying hard to loft this. i cant understand why it would not?
Can any of you figure this out for me, please.
Solved by CCarreiras. Go to Solution.
Hi!
You need a loft, but not as you are thinking, i guess.
Its better do one part and then make a circular pattern to achive all part
I dont have Inv 2013, so i 'm sending you the model in step format.
But i can explain how to do it, if you will.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
Nevermind!
I got it, thanks again.
Hi!
It's a little moere then this.
First objective: create the surface with loft.
1 - Create a construction plane (chose the central axis and a poin of the octahedron near your "vertical" skecth2)
2 - Open sketch2 and copy the geometry
3 - Create new sketch (sketch8 in the image) and paste the geometry. Transform the copyed geometry in "block" to maintain the form intact.
project the points from both tetahedrons and conect the copyed geometry to these two projected points.
4- Now you have two sketches (your in red iand the new in blue), you can perform the loft: open the loft tool, change to surface mode and chose both sketches.
Now you have a nice surface. End of first objective.
And yet a simplier approach. I am using 2015, but here is a video of how I did it.
http://screencast.com/t/ElkjjApoNz
Kirk
Art - I should say its nice & simple with out involving surfacing tools. Thanks.
This fo
Had some difficulty with top of the pole. was able to manage though. Here is a final model.
Thanks for the support.
Hi! The part can be created using Loft feature. However, it cannot be done in just one Loft. It requires multiple Lofts. Loft has an internal restriction on how the face should behave along the section progressing direciton. The faces in that direction has to maintain smoothness (at least tangent continuous or curvature continuous).
Thanks!
