Does anyone know if you are able to do a radial section cut? I am trying to take a section of a top view looking down on a coil and there is a bolt row I want to take a section cut down. I can't find any answers on the web for this.
You can do a multi-segment Cut-Line, but your end lines must be parallel to each other to define your view direction. Like your J-J view. Your G-G view won't work because of the directions are at 90d to each other
