Inventor General Discussion
rdiamond113
Message 1 of 4 (219 Views)
Help with Custom iProperties!
219 Views, 3 Replies
08-21-2013 04:00 PM
Hey All,
I'm having trouble linking normal parameters to my custom iproperties. Is there a way it can be done or do I have to use iLogic?
Inventor 2014, Windows 7, 64 bit
"Pushing the envelope, just to watch it bend"
Distinguished Mentor
pcrawley
Message 2 of 4 (206 Views)
Re: Help with Custom iProperties!
08-21-2013 05:22 PM in reply to: rdiamond113
It's not clear what you are trying to do...
Are you creating a custom iProperty and then wanting to pass its value to a standard iProperty?
If yes, in the standard iProperty, just enter   =<custom_iProperty_name>
If you are going the other way (standard iProperty to custom iProperty), enter the standard iProperty name as the value for the custom iProperty:
Peter
rdiamond113
Message 3 of 4 (159 Views)
08-22-2013 08:02 AM in reply to: pcrawley
My main goal is to populate custom iproperties I've created with parameters that are automatically generated when you create a part or assy
*Expert Elite*
Curtis_Waguespack
Message 4 of 4 (150 Views)
08-22-2013 08:48 AM in reply to: rdiamond113
Hi rdiamond113,
You can export a Parameter as a custom iProperty using the checkbox shown here:
This might be all you need to do since a new custom iProperty (called Pawl_Length in my example) is created. But if you still want to reference the exported Parameter into a new custom iProperty you can do it by adding an expression as pcrawley mentioned. Once you type in the expression click Add/Modify, then Apply:
To edit the expression right click and choose Edit Expression as shown:
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Post to the Community
New Post
Need installation help?
