Good Morning,
I am having trouble with checking in components of Assembly machine that I hadf built (See Attached). When I go through Vault and check-out all using the IDW file and go to check it all back into Vault after I had made changes this is the message, I have been receiving, can anyone help me with this issue.
Thank You
Neil J
Neil,
What I would do is check out your model assembly. Do a component replace of the components listed in your image and select them from vault. Then you should not have any more issues.
Like the message says, it cannot check in this assembly model because those components already exist and for whatever reason the system thinks they are different then what already exists in the vault. Hope this makes sense.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
