Hi! I am trying to make a merry go round in a playground there is a picture for further imagery. To get the array of colors I've tried to make 8 traingles with arcs on the bottom (arc sectors to be more clear) and I can't get them all to be the exact same size. Also, I am worried that the size that I've chosen doesn't fit the circle entirely. Since there are 8 arc sectors, each arc measure would be 45. How do I measure or edit the arc by degree? Thank you!
Solved by IgorMir. Go to Solution.
It seems to be pretty straight forward project to me... Here it is, in sheet metal. Files are in IV2010 format
Cheers,
Igor.
