I'm having difficulties flatening this part, I have no issues doing it with InvR7, I'm now using 2011, any help would be great.
Solved by Dennis_Jeffrey. Go to Solution.
I was curious so I opened it. (Far from an expert on this type of issue.. iges--flat pattern,etc..)
#1-The thickness of the part varies.. Some places its like .079"..others .065"..
The unfolder in Inventor has gone through many changes over the past 5+ releases
I don't think the unfolders like non-uniform thicknesses nor unfolding surfaces.
I'm sure others will chime in with better answers..
You are correct... 🙂
