I2013.
I need a little help from someone better at sheet metal than me. In the attached assembly I am having problems adjusting the length of #400 and #402 to get them to meet in the center with a small gap instead of an overlap. I have tried using Move Face to adjust all the faces on the large end at the same time, and I get a: Could not split between bend and plate error. I could make an adjustment when I save a DXF for waterjet, but I would prefer to have the assembly actually show everything correctly. And not just have a note on the drawing stating that an adjustment has been made in the DXF.
