Hi all,
I have a sheet Metal Model, I am unable to Unfold the sheetmetal part, Its i a coical shape.
can find the file as an attachment.
any Suggestion or help will be highly appreciated.
Md.Asif
Use Contour Roll command to create your feature. Hope can help.
Steps:
1. Open above file and Delete Revolution1, make sure uncheck "consumed sketches and features"
2. Edit sketch1, make rectangle to construction line
3. Create a centerline for small side(0.4mm)
4. Start Contour Roll command, select centerline as profile and select your axis to create Contour Roll1
5. Delete Flat Pattern and recreate.
There is a difference between your sheet metal style (0,5) and the thickness of the profile (0,4) and a redundant point on you profile. Use Sketch doctor
