Inventor Forum
!!HELP!! Sending an assembly via e-mail !!HELP!!
10 REPLIES 10
Message 1 of 11
4060 Views, 10 Replies
Afternoon guys,
Having a bit of a problem sending an assembly via e-mail.
Basically I am trying to send an assembly but I dont want them seeing the dimensions of the parts, so just wondering is there a way to send the assembly without sending the individual parts? If so how?
Thanks in advance!!
AJ
10 REPLIES 10
Message 2 of 11
Cadmanto
Open up the assembly, suppress the parts you don't want seen or included, then save the assembly file as either a step, parasolid or iges file.
Understand that what ever is left can still be measured.  Can't doing anything about that.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 11
Ryan.Martinez
Try using shrinkwrap
P.D.S. 2015
P.D.S. 2016
Message 4 of 11
fakeru
Make a derived part of the assembly and breake the link. You can also scale it to whatever scale you want if you don't want them to have the correct sizes.
Regards
Alexandru
Autodesk Inventor 2015 Certified Professional
Message 5 of 11
in reply to: Ryan.Martinez
Hi guys,
Thanks for quick reply, I converted to STEP & Igs files but now some materials are not converting over (stainless steel)
Never used shrinkwrap and just had a quick look but it filled in the holes with a cream colour? is that normal and when my client opens the file will they be there?
How to get derived part?
AJ
Message 6 of 11
fakeru
How to create derived part:
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126/0127-Inventor127/0340-Derived_3...
In the picture attached you will see how to break the link.
Good luck!
Message 7 of 11
Cadmanto
AJ,
The downside of creating a step, iges or any such file is it creates a dumb solid.  Meaning any parameters or properties are not carried over from the original.  You can add them to the dumb solid, but they will not carry over.
Best Regards,
Scott McFadden
Message 8 of 11
in reply to: Cadmanto
Hi Scott,
That makes sence, so wont be doing that then as have different materials!
Currently trying the derived part option!
Thanks agains!
AJ
Message 9 of 11
mcgyvr
ANY 3d file you send can be measured/dimensioned..
Message 10 of 11
GosponZ
pack and go.
Message 11 of 11
JDMather
What is the purpose on their end?
Maybe a 3D *.dwf is all they need.
