Inventor General Discussion
New Member
0 Kudos
Post 1 of 2
help placing a hole in the outside of a curved surface like a soup can.
175 Views, 1 Replies
10-22-2013 02:56 PM
I'm trying to learn Inventor so I can help my kids with their class at school. I trying to sketch a part with a hole toward the top of a cylinder. I want the hole to be 1/2 in. down from the top. The help topics I have viewed suggest placing a plane on the outside of the can and a point on that, then drill the hole at that point....I can't figure out how to place the plane.....Help!
Hi b.degraff,
This link illustrates the steps to create a Tangent Workplane using an Origin plane:
http://help.autodesk.com/cloudhelp/2014/ENU/Inventor/files/GUID-6A0C52F4-D4C1-48FC-BFB8-7F7056D2AAE9.htm
Edit:
 This animation shows it well also (credit to JDMather for the animated GIF file).
I hope this helps.
Curtis
1,708 Kudos
Post 2 of 2
Re: help placing a hole in the outside of a curved surface like a soup can.
10-22-2013 02:59 PM in reply to: b.degraff
Hi b.degraff,
http://help.autodesk.com/cloudhelp/2014/ENU/Inventor/files/GUID-6A0C52F4-D4C1-48FC-BFB8-7F7056D2AAE9...
Edit:
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
