Inventor Forum
Help on unfolding a solid part
3 REPLIES 3
306 Views, 3 Replies
Hi there ,
I want to unfold a solid part Using Inventor, the part file is attached is anyone knows pleae do let me know. the part file consist of a base and a cylindrical feature. I am looking to unfold the cylindrical part. i have tried converting it into a sheetmetal and cut the cylinder  then also it dose not works.
Thanks- Md.Asif
3 REPLIES 3
CCarreiras
Hi.
You have to understand the concept of a part and assembly.
If you want to flat one part you must have only that part you want to flatten.
Check the part attached.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
CCarreiras
in reply to: CCarreiras
Hi!
Part attached.
CCarreiras
Thanks you very much Carlos .
Regards
Md.Asif
