Inventor Forum
Help needed with wire model
13 REPLIES 13
Message 1 of 14
JPDu
737 Views, 13 Replies
Hello there,
I have some issues and can't seem to find the answer any place. I am currently trying to open up some product models to render some good product images, and I have access to the following file types: .3ds, .igs and .dwg
When I attempt to open the .igs all I have is wires.
When I open the .3ds in Max the surfaces are randomly flipped inside out.
And I am unaware of using the .dwg as a 3d model so that I can render some nice shots.
Suggestions please? I think the .igs has the most potential, I just don't know how to turn this into a solid:
13 REPLIES 13
Message 2 of 14
CCarreiras
in reply to: JPDu
Hi!
Post the model and we will see....
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 3 of 14
wimann
in reply to: JPDu
J,
I want to say that I've had some luck creating surfaces and/or stitching surfaces in an .igs model to create a solid but it has been a while so I'm not 100% certain.
And as long as the cad file is a 3d file you should be able to do that. Or open it in cad and export it as a step file.
At any rate, Carlos is right. You'll get a much more definitive answer if you post the file here so that we can give it a whirl.
-Will Mann
Inventor Professional 2020
Vault Professional 2020
AutoCAD Mechanical 2020
Message 4 of 14
JDMather
in reply to: JPDu
@JPDu wrote:
And I am unaware of using the .dwg as a 3d model....
File>Open and set the Options to Import.
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
Message 5 of 14
JPDu
in reply to: JDMather
Here is the IGS file. Thank you for your quick replies! Very much appreciated.
Message 6 of 14
JDMather
in reply to: JPDu
Let's take a look at what you have in the DWG file.
Attach it here.
Message 7 of 14
JPDu
Thank you JD. Here is a DWG of an actuator which I cannot seem to import properly. It is supposed to look like this:
Message 8 of 14
JDMather
in reply to: JPDu
Unfortunately you have nothing but wireframes - you will have to model the parts.
Fortunately - they are fairly simple parts to model.
Message 9 of 14
JPDu
So no luck with the IGS either? I could supply the .3DS as well. Maybe its something I missed when importing?
Message 10 of 14
wimann
in reply to: JPDu
You can upload the .3ds if you want and I can see try opening it. Though if you're getting these from a client or manufacturer, the best file format is probably a step. Have you tried asking for a .stp?
-Will Mann
Message 11 of 14
JDMather
in reply to: JPDu
@JPDu wrote:
So no luck with the IGS either?...
Not a matter of luck.
The IGES opened fine.
But there no solid geometry in the file - only wireframe.
Message 12 of 14
JPDu
in reply to: wimann
Some of the models had a step file, which opened perfectly and I have been able to render some great shots. However others only have a .dxf .igs .dwg and .3ds. Very frustrating that I can't open any of them... What could have caused this?
I have attached the .3ds model.
Message 13 of 14
JPDu
I see, is there any simple way to surface the model rather than doing the whole part over from scratch? I was looking at loft commands, however I am relatively inexperienced when it comes to such features.
Message 14 of 14
JDMather
in reply to: JPDu
Sure, but since the geometry is would be simple cylinders and primatic - it would be far faster to use the given wireframe only as reference and remodel as solids.  I would not take the time to surface a faceted wireframe.
Probably about an hour to model as solids
and 3 hrs to surface the wireframe facets.
