Inventor General Discussion
0 Kudos
Post 1 of 14
Help needed with shell command
2592 Views, 13 Replies
11-02-2011 12:21 PM
I need help with shell command. When i want to shell my product, program gives this error: Shell1: Could not build this Shell. The attempted Shell operation had non-manifold inputs. Try with manifold inputs. How can i fix this problem ?
Sorry for my bad english.
Thank you for your time.
 Appreciations.
While I take a look at your geometry - you might take a look at this document http://home.pct.edu/~jmather/skillsusa%20university.pdf
I noticed that your First sketch isn't constrained and it looks like you might be doing too much work to get the geometry.
Maybe something like this is what you are after (see attached)
Took another look - Loft IS easier (see attached).
655 Kudos
Post 2 of 14
Re: Help needed with shell command
11-02-2011 12:42 PM in reply to: oopisteinepoiss
Your English is excellent.
Your ability to fully constrain sketches is not so great.
Loft4 is the problem. Pull the end of part marker up over Mirror2 and look at the flat face of your first loft. There is a void there between loft3 and loft 4.
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
2,126 Kudos
Post 3 of 14
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
0 Kudos
Post 4 of 14
11-03-2011 02:06 AM in reply to: JDMather
Thank you for such short notice, but there is still one question that remains. Why sweep tool connects to solids when loft tool isn't able to do it ?
Thank you for your answer.
Appreciate your help.
2,126 Kudos
Post 5 of 14
11-03-2011 04:04 AM in reply to: oopisteinepoiss
Loft  is able to do it - if you set up the problem correctly.  But it looked to me like Sweep would be less work.  Why do more work?
If the sweep doesn't give you desired geometry, we can keep working on a more complex Loft solution.
2,126 Kudos
Post 6 of 14
11-03-2011 05:47 AM in reply to: JDMather
New Member
0 Kudos
Post 7 of 14
01-03-2012 01:41 PM in reply to: oopisteinepoiss
please help im trying to hollow out a box but no matter what i do it keeps on saying try manifold inputs, also i attached you file but it would not load on my software please tell me step by step hows to make a shell
thanks
your answer is valued
2,126 Kudos
Post 8 of 14
01-03-2012 01:46 PM in reply to: AminaShab
Attach your ipt file here.
 If the file size is too large - find the red End of Part marker in the browser.
Drag the red EOP marker to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
In Windows Explorer right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Member
0 Kudos
Post 9 of 14
04-15-2013 09:37 AM in reply to: oopisteinepoiss
I'm having the same problem trying to shell this part. I've redone the loft based on previous comments but hasn't madea  difference. Any help would be greatly appreciated! Thanks.
Distinguished Mentor
139 Kudos
Post 10 of 14
04-15-2013 10:08 AM in reply to: keith_velishek
