Inventor Forum
Help needed with headphone design
9 REPLIES 9
Message 1 of 10
MarkYoung94
1418 Views, 9 Replies
I'm a noivice at inventor and I'm working on a project for someone to make some headphones that he desgined. He said that they're based off of the apple iPhone headphones but I'm having some trouble getting to that. There is sapose to be a curve from the speaker to the stem but I can't find a way to get this done. I was thinking I should of done a sweep instead but when I did that I just came out wrong. Any help would be greatly appreceated!!!
9 REPLIES 9
Message 2 of 10
PaulMunford
in reply to: MarkYoung94
Can you post an image of what you are trying to achieve?
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Message 3 of 10
JDMather
Your Sketch1 is not constrained.
Instead of making use of symmetry about the origin planes you are creating your own workplanes?
You might start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
You might also install Service Packs 1 & 2 and be sure to indicate when you aren't using the latest release of Inventor (2013).
The CADWhisperer YouTube Channel
Message 4 of 10
MarkYoung94
in reply to: PaulMunford
here's a pdt of what he wanted. its very dificult to work with since he didn't provide all the demntions
Message 5 of 10
blair
Looks like a school project, as the drawing supplied is a basic Inventor template. Someone has already created a Inventor model to get the views on the drawing.
If I was contracted to do this, it would be a Inventor assembly file which would contain all the parts required to build the ear-bud.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 6 of 10
MarkYoung94
in reply to: blair
No its a drawing done in PhotoShop I'm trying to recreated it best I can
Message 7 of 10
The pdf you posted contains an image of your own Inventor model on a drawing sheet with four views and no dimensions. It is not a 'Drawing done in Photoshop' . Are you sure you attached the correct pdf ?
Regards
Martin
Inventor 2023
Message 8 of 10
sorry here is the correct pdf
Message 9 of 10
blair
Loft with Rails should work for your shape, Inventor's help function will get you what you will need.
Delta Tau Chi ΔΤΧ
Message 10 of 10
JDMather
You might go through all of the tutorials in my signature.
That will be a challenging design for a beginner.
