Create a line INSIDE the same sketch for the rotation axis.
If you are using an origin axis for the rotation axis PROJECT the axis in
the same sketch.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
wrote in message news:5932953@discussion.autodesk.com...
Hi! I tried to search for similar topics, but didn't find any- guess my
question is too basic. But I need help.
I want to create a rotational object. So I created a sketch, drew the
layout, set dimensions and constraints (there are still 6 missing, but all I
get are driven dimensions by now).
Now I want to rotate this around an axis. When I choose Part Features>Rotate
it does rotate my layout and create a rotational part, but it's way to close
to the axis. I also can't dimension the distance to the axis.
How can I do this?
I quit the sketch and created a work axis on my y-axis, but still can't
relate this to my layout in the sketch.
I can't create a work axis in my sketch.
Thanks for any help! I think I'll have some more questions later 😕
