Inventor Forum
Help is not available
7 REPLIES 7
Message 1 of 8
JGR44
530 Views, 7 Replies
I can't access online Help, an error message comes up ( see attached)
I've downloded and installed Loca Help, same result same error.
Inventor only.
No problem with AutoCAD 2015 Help.
Any suggestion for solution please
Julian
Inventor Professional 2015 update 2
Windows 7 professional - 64 bit
16 GB RAM
7 REPLIES 7
Message 2 of 8
blair
in reply to: JGR44
Did you change the setting in Inventor in the Application Options to use the Off-Line Help. Even though you installed the Off-Line Help, Inventor needs it's setting to change. The setting should be in the lower LH corner of the first screen.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 8
JGR44
in reply to: JGR44
Yes, I did.
In Application Options/ General/ Help options the "Autodesk online help" radio-button is on.
Julian
Message 4 of 8
blair
in reply to: JGR44
This should be set to Installed and it should show that Local Help is available, which means it's installed and Inventor see it.:
Delta Tau Chi ΔΤΧ
Message 5 of 8
JGR44
in reply to: JGR44
Thanks Blair.
I think I have to re-install Help, since both radio bottons are greyed out (see attached)
Julian
Message 6 of 8
blair
in reply to: JGR44
There is two parts to this, first download the file, then run the executible to extract the help file and install it to the Inventor Help directory. I would make sure that you have logged in to your machine as the Administrator to do this.
Delta Tau Chi ΔΤΧ
Message 7 of 8
JGR44
in reply to: blair
Thanks Blair
I'll give it a go soon
Julian
Message 8 of 8
JGR44
in reply to: JGR44
Thanks Blair
Problem solved
Merry Christmas to you and everybody in the forum
Julain
