Inventor Forum
Help Inventor Professional 2015 Ray Tracing
12 REPLIES 12
Message 1 of 13
1315 Views, 12 Replies
I just build my computer.
I have a Nvidia Quadro k4200 graphics card.
I am running Inventor Professional 2015, though when I go to see a realistic view mode, I enable ray tracing and it will just quit afterwards.
I have installed all hot fixes and service packs. Changing the hardware options does not help aswell.
Matthew
12 REPLIES 12
Message 2 of 13
CCarreiras
Hi!
The pc overheat and shutdown.
Lower the Ray tracing definitions.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 3 of 13
in reply to: CCarreiras
My compjuter isn't even close to over heating, and no I click the button and it says enabling ray tracing then it just unexpectedly shuts down.
Message 4 of 13
-niels-
This sounds like a similar problem to:
http://forums.autodesk.com/t5/inventor-general-discussion/inventor-2015-ray-tracing-problems/m-p/523...
Maybe the solution in there can help?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 5 of 13
in reply to: -niels-
Changing the mode doesn't help either, I have also tried trinstalling and re installing windows and inventor as well,
I don't know how to fix it...
Message 6 of 13
mcgyvr
Did you try "software graphics" option in application options/hardware tab?
and how about updating your graphics card driver?
Message 7 of 13
in reply to: mcgyvr
I have tried software graphics as well.
My computer has the latest graphics card driver for my computer aswell.
Message 8 of 13
DarrenP
raytracing is cpu based
what is shutting down inventor or your computer?
DarrenP
Message 9 of 13
in reply to: DarrenP
Im not sure, I have an intel i7 4930k. 6 Cores.
When I click ray tracing it says enabling ray tracing, then it will close the program, no error or anything just closes it out.
It starts buckup with no problem as well.
Message 10 of 13
CCarreiras
Hi!
But this shutdown happens even if you have lower defenitions in Raytracing?
CCarreiras
Message 11 of 13
Well it wasn't working.
I just no uninstalled it and restarted my computer and re installed it. 2nd time uninstalling,
Now the rendering options works like a charm on all setting. 🙂 Hurrah
Message 12 of 13
TADA, Note: I did not make this model, just using it as a test.
161 seconds is great I think, On conservative
Message 13 of 13
Second raytrace 138 seconds, performance
