You should use the DA to rename parts in order to keep the relationships intact.
What if you hide part B (zip it up) and open the IDW, if it asks can you point it to Part
A now?
Also Please don't cross post to multiple files.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Christian" wrote in message
news:136FF3592237973977BECFE68000981A@in.WebX.maYIadrTaRb...
> Can someone help me please. In the paper drawing part of inventor I created
> a view that was referencing PartA.ipt. I happened to change the file name of
> PartA to PartA-1. Now inventor doesn;t see PartA since I changed the file
> name and instead is referencing a PartB.ipt. Is there any place where I can
> edit what file the VIEW is referencing to?
