Inventor General Discussion
Valued Contributor
Justin_Desilva
Message 1 of 7 (236 Views)
Help - How can I select and hide a surfaces or bodies in the workspace?
236 Views, 6 Replies
09-12-2012 05:20 PM
I understand how to select and hide surfaces and bodies using the model tree, but this isn't useful when my part has 50+ surfaces and solids and I'm forced to hover over each surface or body until the surface or body I want to hide is highlighted. This is possible using Soildworks but why not Inventor?
Shift RMB
Change your selection filter to Bodies.
JDMather
Message 2 of 7 (232 Views)
Re: Help - How can I select and hide a surfaces or bodies in the workspace?
09-12-2012 05:47 PM in reply to: Justin_Desilva
Don't you have a folder at the top of the browser that says Surface Bodies?
Can't you right click on the folder and unselect Visibilty?
How is this different than SWx?
Can  you roll up the EOP and attach the file here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
Justin_Desilva
Message 3 of 7 (229 Views)
09-12-2012 06:06 PM in reply to: JDMather
I can select and hide both sufaces and solids in the manager tree folders, but what I'd like to do is select a surface or solid in the viewport, right click, and select hide.
JDMather
Message 4 of 7 (224 Views)
09-12-2012 06:17 PM in reply to: Justin_Desilva
Shift RMB
Valued Contributor
Justin_Desilva
Message 5 of 7 (221 Views)
09-12-2012 06:25 PM in reply to: JDMather
Can you tell me where the selection filter option is?
Valued Contributor
Justin_Desilva
Message 6 of 7 (220 Views)
09-12-2012 06:29 PM in reply to: Justin_Desilva
I understand now. Hold shift, then right click, then select Select Bodies.
Sorry everyone, for some reason I was not able to take a screen capture.
Thanks JD.
JDMather
Message 7 of 7 (195 Views)
09-13-2012 04:16 AM in reply to: Justin_Desilva
There is also an icon for setting selection filters in the upper left area of the screen.
