Inventor General Discussion
*Expert Elite*
JDMather
Message 11 of 13 (67 Views)
Re: Help converting to DXF files
06-21-2013 04:53 AM in reply to: mansugi
Your design is not ready yet to send to manufacturing.
For example, rightfrontplate doesn't have any dimensions and if I start adding dimensions - they don't make sense.
I recommend you read this document
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
When you use Bolted Connection - I recommend you set the Custom tick so that your fasteners are saved local in your project.
I recommend that you do not rename files as they are hyperlinked in the assembly - when you rename the "address" is lost.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
*Expert Elite*
mrattray
Message 12 of 13 (66 Views)
06-21-2013 05:01 AM in reply to: mansugi
My preferred method for exporting dxf's for nc work is to create a flat patten and RMB on the Flat Pattern browser node>Save Copy As. (You can do this with parts that aren't sheet metal, too.) There's lots of useful options for compatibility with nc software, like converting splines to lines & arcs, layer controls, etc. and there's no chance your files going to come out at a wonky scale or with title blocks like when you're exporting from a drawing.
Mike (not Matt) Rattray
Member
mansugi
Message 13 of 13 (54 Views)
06-22-2013 09:59 AM in reply to: JDMather
Wow.....After reading all these replies....I am lost.
I am very new with CAD. I have no clue at all. I learned all these stuff thru youtube and manage to do those files that I need for a personal hobby project. Also that was the reason why I used the student version.
Anyway....I've read all those pdf.....and then realized what you guys talked about is all over my head.
Just wondering if any of you can really help me with this project. Now I have no confident of sending these files because I am afraid that all the dimensions are wrong. All I wanted are files that I can sent it to a local waterjet cutter so he can do the cutting.
Please let me know if you can help. We can go off-board.....if we have to.
Thanks again for all the replies and suggestions.
Az
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
