hello,
I have this part: http://tinyurl.com/inventor-part12
However when I try to export to .STL it won't do it because it is only surfaces and not a solid.
I have searched everywhere on how to convert from surfaces to a solid but nothing I have tried has worked.
I would really appreciate it if someone could just convert the file for me.
Thank you times a million to whoever can help me with this problem!
This is something I have wreseled with in the past. I would love to find a better solution than my current method. I will import the solids file into autocad and explode the geometry to remove the solids info. I then save the geometry as a dwg but I belive you can export to stl.
I admit this a klugy and sometimes unreliable way to go about the problem, but as I said I'd love to find a better one. I use this method when importing into sketchup BTW.
thank you so much. I really appreciate it.
email me at jameshutton@live.ca if you want.
thanks
I just realized I read your question backwards, the method I described is to convert a solid to surface, going the other way is another story. Was autocad able to translate the file?
no I havent been able to no matter what I've tried. All I need is to export an STL file from the file I posted in the link
You need to upload 'box simplified.ipt' as well otherwise the assembly (.iam) file you have already posted is of no use.
Regards
Martin
Hi, you don't need to derive your assembly into another part (Part1.ipt) and upload. Part1.ipt file will look for the file it was derived from, in this case longboard embers box.iam which contains 'box simplified.ipt'. You need to upload 'box simplified.ipt' as this is the file you want converted into a solid.
Regards
Martin
Attached is a solid conversion of the only surface part you have attached here.
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
