I have an assembly and all parts and subassemblies shows a questions mark, yesterday when I finish my work everything was ok. today when I open the file it does not show me anything. you can see the file attached
Solved by blair. Go to Solution.
Welcome to our group.
Those question marks mean that Inventor cannot find your files. Either they were deleted (doubtful?), or whatever location they are saved in has not been added to your search path.
Are you working on a network, or using Vault?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
It could be you are using a different Project File and the unresolved files are not within the scope of your current project.
As also stated, these files could have been deleted, stored on a network drive or other location that is currently unavailable to your machine and Inventor.
Thank you for your answer. I understand what you told me but I do not know how fix it.
I am working on a network
Can you access all your network drives and folders where your Inventor files are stored. It be as simple as a reboot of your machine, possible a reboot of your server as well. It could even be a network cable unplugged or a faulty NIC card.
First go to Get Started > Projects. Make sure your project is set to where you have the files. Sometimes Inventor will default to default. If the files are not in the project folder, or in a different project than set, move the files or change the project. This should make those files available again. But anytime this occurrs, this is the first thing that should be checked. If it is not this, then we will go to the next possible cause. Was it only one or two parts that were unresolved, I would say it was a different cause, but being they all are, this is the most likely cause in this case.
