Yes, I tried that Laurence. It won't work in this case 😞
"Laurence Yeandle" schreef in bericht
news:D31DEEF58144E76655271FA6CF34CC1C@in.WebX.maYIadrTaRb...
> See CF for an example using transitional constraints, the way to get it to
> work is to pick the follower then the smallest rad on cam in this order.
> Laurence,
> Power is nothing without Control
> "Christian Niemarkt" wrote in message
> news:5B3AC33F781848C599C47E9E86F1D45F@in.WebX.maYIadrTaRb...
> > See CF for JPG.
> > I tried to "drive constrain" this Cam by using a transitional constrain,
> but
> > that doesn't work in this case.
> > It moves partily over the curved part but not the full 360.
> > Now I was thinking, is it possible to constrain "A" to "B1" en use 4
> > equations to determine the distance between the 2 centers according to
> alfa
> > (angle)?
> > So as alfa changes, the centerdistance changes. In that case you could
> drive
> > constrain alfa.
> > Or is this something that could/should be done in VBA?
> > This 4 equations are:
> > 1 - 0-75 degrees - Radius=160+90
> > 2 - 75 -165 -
> R=160+90((160/90)*alfa-(160/2Pi)*sin(360*alfa))
> > 3 - 165-270 - R=320+90
> > 4 -
70-360 -R=160+90((160/90)*alfa-(160/2Pi)*sin(360*alfa))
> > I hope that you understand what I am trying to do.
> > Thanks.
> > Christian
