Charles,
Cool use of the pattern along path option. Very elegant.
I have another possible method but it requires MDT. (see files posted as reply to Charles file post in CF)
Using the old Spiral.lsp file (circa R12) you can create a 3Dsprial. Use this as the path for a swept surface or native AutoCAD solid (assuming you want a spring around which to wrap the second helix) Now take this same helix path and convert it to an augmented line and twist the vectors to the desired pitch. Now draw the cross section of your second helix. Sweep this cross section along the augmented line as a surface. If you create trimmed surfaces at each end of the resulting surface, you can stitch it into a solid. In the example I posted (I think I posted it properly), you will see that the cross section of my second helix is not quite round. This is because I did not rotate the plane on which I drew it to be perpendicular to the path. To do this, the math needed is found in my Machinery Handbook 25th edition page 1856. Ive used these same formulas for helical gears.
I was able to translate these into IV but because I didnt stitch the surfaces in MDT, I had to promote the surfaces up from the construction environment.
Does anyone know the legality of posting the sprial.lsp file since it came with an old version of AutoCAD and may be copyrighted? Or, where it might be found?
I hope this helps,
Roger James
Motor City CAD
