Inventor Forum
Helicoil Tap Info
11 REPLIES 11
Message 1 of 12
3761 Views, 11 Replies
Helicoil Tap Info
Is there a way that I can add helicoil tap info to the thread size spreadsheet so that I can use the data within the hole command and place helicoil-tapped holes into my models? I need some way to automatically flow the helicoil tap info into the drawing via a hole note.
11 REPLIES 11
Message 2 of 12
You should be able to create a worksheet in the threads.xls spreadsheet
(design data folder).
You'll need to know the sizing information, but I'm sure that's not a
problem.
Derek
wrote in message news:5583322@discussion.autodesk.com...
Message 3 of 12
Hello Bakerman,
please let me know if you want to use metric coarse or metric fine, Inch coarse or inch fine. So i can post the neccesary raw data (excel sheet) to build the thread size spread sheet in the thread.xls
Best regards
Matthias
Message 4 of 12
We generally use inch coarse only.
Message 5 of 12
M. Peppel-
I was wondring if you still have the helicoil files?  I was looking at getting both the inch coarse and the inch fine.
Message 6 of 12
rdyson
Here's my thread xls. Copy the helicoil sheets to yours.
No guarantee on accuracy, if it's important double check it.
PDSU 2016
Message 7 of 12
I have just found the .xls file with helicoils. I have copied it but I do not get correct information. When I select a hole from the pulldown inside Inventor (2013 BTW) it says it is a 1/4-20 Helicoil but when I add a hole note on the drawing it only refers to 1/4-20 thread - no helicoil note.
The metric file works as expected. Any idea as to why?
Message 8 of 12
rdyson
Seems to work for me, maybe your styles?
PDSU 2016
Message 9 of 12
Thanks for the help.
Message 10 of 12
Hello Matthias,
Can you send me an Excel sheet with the metric helicoil coarse (if not asking to much: also the metric fine)
thanks
Stefan
Message 11 of 12
SBix26
@Anonymous has not been active on the forum for more than a year, so may or may not see your request unless you ping him as I have done at the beginning of this sentence (just type the '@' symbol and you can find the user you wish to notify).
Sam B
Message 12 of 12
in reply to: SBix26
