Inventor Forum
helical gear
11 REPLIES 11
Message 1 of 12
1082 Views, 11 Replies
helical gear
need an ipart for helical gear cananyone help please
11 REPLIES 11
Message 2 of 12
Gears are very complex depending on application. You will need to supply specifications for what you want. Unless you are actually manufacturing the gears - simplified friction discs will do the job and not bog down your assemblies.
Message 3 of 12
Not an iPart, but you can 45deg Helical gears here...
http://www.bostongear.com/
Don A 🙂
Message 4 of 12
You could download Mechsoft. http://www.mechsoft.com The demo should be good for about 15 Days and very likely create the gear you need. You might also try Ole Germer's Site (Timken bearings, Involute Gears, Roller Chains etc.) http://www.geocities.com/olegermer/index.html hotsam wrote: >need an ipart for helical gear cananyone help please > > > >
Message 5 of 12
You can try this. it is really fantastic, but it still trial version 😞
http://www.mechmagic.com/distributive/GearsALL/gearsPRO/gearsPRO.zip
Message 6 of 12
Can any reply to mys posted query of Helical Gears. I have attached gear data  & Gear .ipt files..
Message 7 of 12
This reminds me that there needs to be a way to permanently close topics on this forum!
Message 8 of 12
JDMather
I do not see any attachments?
Are you familiar with the Gear Generator Design Accelorator in Inventor?
Message 9 of 12
Message 10 of 12
I have posted it under my Name shrikant murkute . Subject is
"Helical Gear REVIEW Needed and HELP to use Excel Formulae to create variants"  You can look in to the details of the message i have posted along with attachement of .ipt files, & gear data for Helical gears of 19T & 38T. Hope you will get it and understand my query and respond.
I have created 2 Helical gears to be used in a Gear Reducer. I have also attached the Gear DATA dwg. and Gear .ipt files.  CAN any one let me know the helical gear i modelled using the gear data has correct profile as per data. also if you have different approach to generate these helical gears then  Please model New gear .ipt files with this gear data and attached them in your reply message.
I want to use these two gear blanks for creating other variants also i.e.gear combo of 24T & 48T, 26T & 52T. etc.
TO create these i want to use design table of Excel Sheet with formulae . I tried  i am not able to link the Excel file to the model  and also which all parameters should we consider in Excel table to create variants of Helical gear .Can any one help me in this too. ?? Files Attached
Message 11 of 12
JDMather
Are you going to be manufacturing these gears - or do you simply need close approximations for visual representation and then purchase the actual gears from a gear manufacturer?
Message 12 of 12
in reply to: JDMather
I will manufacurting these gears at my gear plant, just wanted to make sure the gears i have modelled have right profile as it should be per gear data and  also solution to my other query i posted in my message.
thanks
Shrikant
