Can any reply to mys posted query of Helical Gears. I have attached gear data & Gear .ipt files..
This reminds me that there needs to be a way to permanently close topics on this forum!
I do not see any attachments?
Are you familiar with the Gear Generator Design Accelorator in Inventor?
Try Traceparts.
http://www.tracepartsonline.net
Search for "Gear".
You'll get lots of good results.
I have posted it under my Name shrikant murkute . Subject is
I have created 2 Helical gears to be used in a Gear Reducer. I have also attached the Gear DATA dwg. and Gear .ipt files. CAN any one let me know the helical gear i modelled using the gear data has correct profile as per data. also if you have different approach to generate these helical gears then Please model New gear .ipt files with this gear data and attached them in your reply message.
I want to use these two gear blanks for creating other variants also i.e.gear combo of 24T & 48T, 26T & 52T. etc.
TO create these i want to use design table of Excel Sheet with formulae . I tried i am not able to link the Excel file to the model and also which all parameters should we consider in Excel table to create variants of Helical gear .Can any one help me in this too. ?? Files Attached
Are you going to be manufacturing these gears - or do you simply need close approximations for visual representation and then purchase the actual gears from a gear manufacturer?
I will manufacurting these gears at my gear plant, just wanted to make sure the gears i have modelled have right profile as it should be per gear data and also solution to my other query i posted in my message.
thanks
Shrikant
