il giorno 26/07/2006 18.28 sdussault ha scritto:
> Does somebody knows a place to find a Helical gear model?
If not for production of the gear, you can generate it by Design
Accelerator (spur gear section), setting the right value for β angle
(>0 for helical gears).
If you need a precise tooth profile for production, then you need a
specific software to generate it.
I tried this one:
http://www.kisssoft.ch/
You can download a demo and try. It saves tooth profile some format
(DXF, IGES), then you can import it as a sketch in Inventor.
M.
