Inventor Forum
Helical Flight
7 REPLIES 7
Message 1 of 8
347 Views, 7 Replies
Helical Flight
I have got a difficult part that I need to get a flat pattern of. I have attached a portion of the drawing here. The item that I am needing is MK#13 in this view. It will have to follow the cone shape then follow the inside of the tube. Has anyone done anything close to this with Inventor? I need some suggestions on how to get started. Thanks -- IV R9, SP1 Dell PWS360, 2.6ghz, P4 2 Gb ram nVidia FX1000 6.14.10.6808Driver 1260x1024x32 bit
7 REPLIES 7
Message 2 of 8
I have got this modeled in Inventor the way that I want it. Problem is I have had to use the loft command to generate the flight. Inventor will not flatten a loft (known limitation).... ???Where was that wish list survey??? Would anyone with the Copra Metalbender add-in be willing to flatten this for me if I send the file? I really can't justify the purchase of Copra just to do this one flat. Thanks Kirk -- IV R9, SP1 Dell PWS360, 2.6ghz, P4 2 Gb ram nVidia FX1000 6.14.10.6808Driver 1260x1024x32 bit "Kirk A." wrote in message news:41755f84_3@newsprd01... > I have got a difficult part that I need to get a flat pattern of. I have > attached a portion of the drawing here. The item that I am needing is MK#13 > in this view. It will have to follow the cone shape then follow the inside > of the tube. > > Has anyone done anything close to this with Inventor? > > I need some suggestions on how to get started. > > Thanks > -- > IV R9, SP1 > Dell PWS360, 2.6ghz, P4 > 2 Gb ram > nVidia FX1000 > 6.14.10.6808Driver > 1260x1024x32 bit > > > >
Message 3 of 8
I'll give it a try tomorrow in AutoPol Kirk. Is the first file what you want? "Kirk A." wrote in message news:4175915f$1_1@newsprd01... > I have got this modeled in Inventor the way that I want it. Problem is I > have had to use the loft command to generate the flight. Inventor will not > flatten a loft (known limitation).... ???Where was that wish list survey??? > > Would anyone with the Copra Metalbender add-in be willing to flatten this > for me if I send the file? > > I really can't justify the purchase of Copra just to do this one flat. > > Thanks > Kirk > -- > IV R9, SP1 > Dell PWS360, 2.6ghz, P4 > 2 Gb ram > nVidia FX1000 > 6.14.10.6808Driver > 1260x1024x32 bit > > > "Kirk A." wrote in message > news:41755f84_3@newsprd01... > > I have got a difficult part that I need to get a flat pattern of. I have > > attached a portion of the drawing here. The item that I am needing is > MK#13 > > in this view. It will have to follow the cone shape then follow the inside > > of the tube. > > > > Has anyone done anything close to this with Inventor? > > > > I need some suggestions on how to get started. > > > > Thanks > > -- > > IV R9, SP1 > > Dell PWS360, 2.6ghz, P4 > > 2 Gb ram > > nVidia FX1000 > > 6.14.10.6808Driver > > 1260x1024x32 bit > > > > > > > > > >
Message 4 of 8
oops, just noticed that this is a pdf. Don't think I can unfold that:) Post the ipt and I'll give it a whirl. "Kirk A." wrote in message news:4175915f$1_1@newsprd01... > I have got this modeled in Inventor the way that I want it. Problem is I > have had to use the loft command to generate the flight. Inventor will not > flatten a loft (known limitation).... ???Where was that wish list survey??? > > Would anyone with the Copra Metalbender add-in be willing to flatten this > for me if I send the file? > > I really can't justify the purchase of Copra just to do this one flat. > > Thanks > Kirk > -- > IV R9, SP1 > Dell PWS360, 2.6ghz, P4 > 2 Gb ram > nVidia FX1000 > 6.14.10.6808Driver > 1260x1024x32 bit > > > "Kirk A." wrote in message > news:41755f84_3@newsprd01... > > I have got a difficult part that I need to get a flat pattern of. I have > > attached a portion of the drawing here. The item that I am needing is > MK#13 > > in this view. It will have to follow the cone shape then follow the inside > > of the tube. > > > > Has anyone done anything close to this with Inventor? > > > > I need some suggestions on how to get started. > > > > Thanks > > -- > > IV R9, SP1 > > Dell PWS360, 2.6ghz, P4 > > 2 Gb ram > > nVidia FX1000 > > 6.14.10.6808Driver > > 1260x1024x32 bit > > > > > > > > > >
Message 5 of 8
Thanks. It will be tomorrow sometime before I can get you the ipt. -- IV R9, SP1 Dell PWS360, 2.6ghz, P4 2 Gb ram nVidia FX1000 6.14.10.6808Driver 1260x1024x32 bit "Jimmy" wrote in message news:41759542$1_2@newsprd01... > oops, just noticed that this is a pdf. Don't think I can unfold that:) > Post the ipt and I'll give it a whirl. > "Kirk A." wrote in message > news:4175915f$1_1@newsprd01... > > I have got this modeled in Inventor the way that I want it. Problem is I > > have had to use the loft command to generate the flight. Inventor will > not > > flatten a loft (known limitation).... ???Where was that wish list > survey??? > > > > Would anyone with the Copra Metalbender add-in be willing to flatten this > > for me if I send the file? > > > > I really can't justify the purchase of Copra just to do this one flat. > > > > Thanks > > Kirk > > -- > > IV R9, SP1 > > Dell PWS360, 2.6ghz, P4 > > 2 Gb ram > > nVidia FX1000 > > 6.14.10.6808Driver > > 1260x1024x32 bit > > > > > > "Kirk A." wrote in message > > news:41755f84_3@newsprd01... > > > I have got a difficult part that I need to get a flat pattern of. I > have > > > attached a portion of the drawing here. The item that I am needing is > > MK#13 > > > in this view. It will have to follow the cone shape then follow the > inside > > > of the tube. > > > > > > Has anyone done anything close to this with Inventor? > > > > > > I need some suggestions on how to get started. > > > > > > Thanks > > > -- > > > IV R9, SP1 > > > Dell PWS360, 2.6ghz, P4 > > > 2 Gb ram > > > nVidia FX1000 > > > 6.14.10.6808Driver > > > 1260x1024x32 bit > > > > > > > > > > > > > > > > > >
Message 6 of 8
The files are attached here that I need flattened. Thanks, Kirk -- IV R9, SP1 Dell PWS360, 2.6ghz, P4 2 Gb ram nVidia FX1000 6.14.10.6808Driver 1260x1024x32 bit "Jimmy" wrote in message news:417593b7$1_3@newsprd01... > I'll give it a try tomorrow in AutoPol Kirk. Is the first file what you > want? > "Kirk A." wrote in message > news:4175915f$1_1@newsprd01... > > I have got this modeled in Inventor the way that I want it. Problem is I > > have had to use the loft command to generate the flight. Inventor will > not > > flatten a loft (known limitation).... ???Where was that wish list > survey??? > > > > Would anyone with the Copra Metalbender add-in be willing to flatten this > > for me if I send the file? > > > > I really can't justify the purchase of Copra just to do this one flat. > > > > Thanks > > Kirk > > -- > > IV R9, SP1 > > Dell PWS360, 2.6ghz, P4 > > 2 Gb ram > > nVidia FX1000 > > 6.14.10.6808Driver > > 1260x1024x32 bit > > > > > > "Kirk A." wrote in message > > news:41755f84_3@newsprd01... > > > I have got a difficult part that I need to get a flat pattern of. I > have > > > attached a portion of the drawing here. The item that I am needing is > > MK#13 > > > in this view. It will have to follow the cone shape then follow the > inside > > > of the tube. > > > > > > Has anyone done anything close to this with Inventor? > > > > > > I need some suggestions on how to get started. > > > > > > Thanks > > > -- > > > IV R9, SP1 > > > Dell PWS360, 2.6ghz, P4 > > > 2 Gb ram > > > nVidia FX1000 > > > 6.14.10.6808Driver > > > 1260x1024x32 bit > > > > > > > > > > > > > > > > > >
Message 7 of 8
I just sent the dxfs to you. If they look okay let me know. If not we can try adjusting compensation methods. "Kirk A." wrote in message news:417595cd_2@newsprd01... > Thanks. It will be tomorrow sometime before I can get you the ipt. > > -- > IV R9, SP1 > Dell PWS360, 2.6ghz, P4 > 2 Gb ram > nVidia FX1000 > 6.14.10.6808Driver > 1260x1024x32 bit > > > "Jimmy" wrote in message > news:41759542$1_2@newsprd01... > > oops, just noticed that this is a pdf. Don't think I can unfold that:) > > Post the ipt and I'll give it a whirl. > > "Kirk A." wrote in message > > news:4175915f$1_1@newsprd01... > > > I have got this modeled in Inventor the way that I want it. Problem is > I > > > have had to use the loft command to generate the flight. Inventor will > > not > > > flatten a loft (known limitation).... ???Where was that wish list > > survey??? > > > > > > Would anyone with the Copra Metalbender add-in be willing to flatten > this > > > for me if I send the file? > > > > > > I really can't justify the purchase of Copra just to do this one flat. > > > > > > Thanks > > > Kirk > > > -- > > > IV R9, SP1 > > > Dell PWS360, 2.6ghz, P4 > > > 2 Gb ram > > > nVidia FX1000 > > > 6.14.10.6808Driver > > > 1260x1024x32 bit > > > > > > > > > "Kirk A." wrote in message > > > news:41755f84_3@newsprd01... > > > > I have got a difficult part that I need to get a flat pattern of. I > > have > > > > attached a portion of the drawing here. The item that I am needing is > > > MK#13 > > > > in this view. It will have to follow the cone shape then follow the > > inside > > > > of the tube. > > > > > > > > Has anyone done anything close to this with Inventor? > > > > > > > > I need some suggestions on how to get started. > > > > > > > > Thanks > > > > -- > > > > IV R9, SP1 > > > > Dell PWS360, 2.6ghz, P4 > > > > 2 Gb ram > > > > nVidia FX1000 > > > > 6.14.10.6808Driver > > > > 1260x1024x32 bit > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Message 8 of 8
Looked great. I'll let you know how they turn out. Thanks again, Kirk -- IV R9, SP1 Dell PWS360, 2.6ghz, P4 2 Gb ram nVidia FX1000 6.14.10.6808Driver 1260x1024x32 bit "Jimmy" wrote in message news:417684e5_2@newsprd01... > I just sent the dxfs to you. If they look okay let me know. If not we can > try adjusting compensation methods. > "Kirk A." wrote in message > news:417595cd_2@newsprd01... > > Thanks. It will be tomorrow sometime before I can get you the ipt. > > > > -- > > IV R9, SP1 > > Dell PWS360, 2.6ghz, P4 > > 2 Gb ram > > nVidia FX1000 > > 6.14.10.6808Driver > > 1260x1024x32 bit > > > > > > "Jimmy" wrote in message > > news:41759542$1_2@newsprd01... > > > oops, just noticed that this is a pdf. Don't think I can unfold that:) > > > Post the ipt and I'll give it a whirl. > > > "Kirk A." wrote in message > > > news:4175915f$1_1@newsprd01... > > > > I have got this modeled in Inventor the way that I want it. Problem > is > > I > > > > have had to use the loft command to generate the flight. Inventor > will > > > not > > > > flatten a loft (known limitation).... ???Where was that wish list > > > survey??? > > > > > > > > Would anyone with the Copra Metalbender add-in be willing to flatten > > this > > > > for me if I send the file? > > > > > > > > I really can't justify the purchase of Copra just to do this one flat. > > > > > > > > Thanks > > > > Kirk > > > > -- > > > > IV R9, SP1 > > > > Dell PWS360, 2.6ghz, P4 > > > > 2 Gb ram > > > > nVidia FX1000 > > > > 6.14.10.6808Driver > > > > 1260x1024x32 bit > > > > > > > > > > > > "Kirk A." wrote in message > > > > news:41755f84_3@newsprd01... > > > > > I have got a difficult part that I need to get a flat pattern of. I > > > have > > > > > attached a portion of the drawing here. The item that I am needing > is > > > > MK#13 > > > > > in this view. It will have to follow the cone shape then follow the > > > inside > > > > > of the tube. > > > > > > > > > > Has anyone done anything close to this with Inventor? > > > > > > > > > > I need some suggestions on how to get started. > > > > > > > > > > Thanks > > > > > -- > > > > > IV R9, SP1 > > > > > Dell PWS360, 2.6ghz, P4 > > > > > 2 Gb ram > > > > > nVidia FX1000 > > > > > 6.14.10.6808Driver > > > > > 1260x1024x32 bit > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
