I have just finished scanning in my Iphone 4 using a 3D scanner. I have opened the scan up in autodesk inventor and i want to create a surface around the scanned image. But i want the surface to be offset my 1mm. Once its offset i want to extrude the surface by 2mm and start adding things to the solid body. Im making a case for the phone just so i can get some expirience with the scanner. Does anyone know how i could do this because i cant seem to create a surface around the phone 😞
Any ideas???
HEEELP is not a very descriptive thread title for those who might search the forum.
Go through the tutorials in my signature.
If you need to know about surface tool in Autodesk Inventor please visit the link below. A simple part is designed with the help of surface tutorial:---
Next time you ask any question please give it a specific problem heading so that people here can understand.
Good luck.
OK, you used iphone 4. Try the Apple forum...
Post a file or picture if you want help.
R.
Dan
Post your file (zipped)
