Inventor Forum
Have two presentation tweaks occur at the same time
8 REPLIES 8
Message 1 of 9
rg97
2569 Views, 8 Replies
Hi all.
I am working on a assembly where I would like a bolt to spin as it goes into it's hole. The best I can get is having the bolt slide into the hole and then rotate, which I attached. I guess I want it to look "realistic."
There is probably some simple answer to this but I'm just having a "blonde moment" and cant figure it out.
Thanks in advance. See video.
8 REPLIES 8
Message 2 of 9
JavaLodge
in reply to: rg97
When you open your animation window, click the double arrow to the bottom right of the box. In the list of components, find the bolt. There should be two sequences associated with it, one that turns it and one that translates it. Select the two and click group. Now both sequences will play at the same time, making the bolt turn as it moves in.
____________________________________________________________
Slow is good and good is fast.
Message 3 of 9
rg97
in reply to: JavaLodge
Java, Thanks. I knew that there had to be some simple solution and you got it.
Message 4 of 9
s.samet
Thank you so much you saved us when we try to make a final project.
Message 5 of 9
lhomutoff
in reply to: s.samet
How do you combine movements "tweaks" of the same part in 2019 Autodesk Inventor. The ipn tools are totally different and the ability to "group" movements from the same part seems to be gone.
Message 6 of 9
RobertKarlsen
in reply to: lhomutoff
Hi! Im asking the same question! 🙂
How can i do the same thing in Inventor 2020
-Robert.
Message 7 of 9
SBix26
in reply to: RobertKarlsen
Timing of tweaks is controlled in the timeline at the bottom of the Presentation screen.  Simply move the tweaks in the timeline to coincide with each other.
Feel free to attach a sample dataset, someone here can show you how to do it.
Sam B
Inventor Pro 2020.0.1 | Windows 7 SP1
LinkedIn
Message 8 of 9
RobertKarlsen
in reply to: SBix26
Ohh... I was looking for that timeline, but the line under the "time scale" was too far up, so i didn`t see it 🙂
Thanks!
Message 9 of 9
townerc
