We just changed to Iv R2011, and there's a new irritation in it... I've been told there's no way to turn it off, so I thought I'd have some fun with it (see attached).
... waaaaay back in the day... (for us older folks, "once upon a time..."), a company called AutoDesk made a product called AutoCAD. They sold this to a person named User. The product worked well, though it did not DO a whole lot. The company improved it over time, and both AutoDesk and User were happy. Then, one day, an evil troll named Microsoft changed the ground upon which AutoCAD stood! The change was monumental, and all involved agreed that Microsoft must be a genius. One of the teeeeny, tiiiny changes was an extra "mousie-click" needed to do things that only one "mousie-click" had done before.... "AHA" thought AutoDesk (and its progeny, SolidWorks, et al...), we have discovered the secret of the troll's genuis... it's "mousie-clicks". Every new release added "mousie-clicks" to every operation, until it took TEN "mousie-clicks" to so what one had done before. And THAT is the reason in Inventor, AutoCAD, and ALLLL the others, it takes an extra "mousie-click" to say "I'm done"... and an extra to say "Yes, I'm really done"... and ONE MORE to say "YES, DARNIT, I'M REALLY DONE!!!"... ) ... aaaandd, NEW in R2011, you must click the green check-mark!!
Well you are in luck kind of.. In 2011 that can be turned off just can't remember how.. But you do have a way..
Thanks... but where's the fun in that? If you happen to remember how to turn it off, let me know, otherwise, it's really not a big deal -- I just seem to make a big deal out of some things.... I used ACAD R12 on DOS until 2000, when we got "Y2K-ed" and had to go to Windows. With DOS, a right-click cancelled the command... with Windows, it gave a drop-down menu, and you had to select the cancel command... I STILL want all those extra mousie-clicks back!!
The usability and efficiency of a user interface is more complicated than just counting mouse clicks. How far you have to move the mouse and how precisely you have to position it also have a big effect.
In the image you attached, where's the inefficiency? You enter the number you want (or drag the arrow if that gives the results you need) and hit enter or click the check box, all in the immediate area where you are working. Very little mouse movement involved.
Not in any way saying that the user interface is perfect, but the example you showed is one of the good things about the recent interface changes.
While I agree wholeheartedly with Sam and generally don't appreceiate rants, I enjoyed your story - it made me smile this Monday morning.
Sam;
The inefficiency comes from the change. Before, I could just hit the "Enter" key, which even 2 months after the change, I still do out of habit. Now, I have to grab the mouse and hunt down the green check mark. I've selected the "New Work Plane" icon (mousie), clicked on the surface to define the new work plane (mousie), then entered the value of the offset (keyboard), then hit "Enter (keyboard). With the new version, I have to use the mousie for the last step. No, it's NOT more keystrokes, just different ones... If there's a real problem, as opposed to a phantom problem, it's with me. But, I do need to ask, where is the net GAIN in the change?
Still works pretty much the same way. Type the value, hit Enter, then hit Enter again. The first one nails down the value you typed in, the second one executes the command.
hmmm.... that's correct... I've still got Iv R2010 on my machine at home, and if I remember to check (which is unlikely, as it requires me to remember) I'll look, but I believe we've picked up an extra "enter" keystroke..... One thing I disagree vehemently with you on is the idea of an interface change. To me, there is NO "good" interface change. If the user interface changes, the change should ADD some value, or it's better left alone. This would seem to be a good example -- we've added a keystroke, but the result is the same. Why add the keystroke? Interestingly, if I decide in the middle of the command that I don't want to make the work plane, I hit "Esc".... yup... TWICE, now.
At my worklace, most of what we do is fairly simple, as the industry is flat plate, angle, and channel steel. We're also asked to work extremely fast. Every time we change releases, it seems AutoDesk has to scramble the user interface, and that only slows us down. I guess no one else feels that way, but to me it's what I call the "regretting having changed releases" phase....
I think what scares me the most is that AutoDesk has used a green and a red check mark, kinda like SolidWorks. Frightens me, as I wonder if AutoDesk is trying to be LIKE SolidWorks, which would be very, very bad.
All that does is when you are in a sketch you will not be able to type in your values as you sketch. It does not turn off the mini menu. I don't think there is a way to turn off that. I've tried.
Let me google that for you
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13187753&linkID=9242018
@Anonymous wrote:Let me google that for you
That option doesn't exist in 2012 or 2013. In 2012 there is a registry key that can be modified to turn off the ribbon, but that doesn't work in 2013, besides, I don't think turning off the ribbon, as your link suggests, is relevant to this problem.
@ Lonesome Joe, My apologies, I didn't realise what mode you were in.
Has anyone even read the post he is in 2011 and there is a way to shut it off in 2011 I just don't remember how.....
Good thing he is using 2011 then isn't it?
I hate the green tick too.
Its not so much an extra work issue.
Its just my sub-conscious brain is programed to follow a basic drafting routine, whlilst my attention is focused on the engineering design. Now, when I finish the routine, my mouse hand (controled by the subconcious brain flies off to start the next inane task and....huh...wtf...ohhh...thats right...now i have to go back and do this extra step of clicking on this tiny little green arrow for no apparent reason.
Im sure ill get used to it eventually and will not have a problem, but in the meantime every year my brain has to adjust to whole new way of doing inane tasks.
I would rather learn more engineering every year rather than have to dedicate a whole heap of brain power and effort to relearn how to do basic tasks.
Im all for change for the better...its the pointless additions that irk me.
richos69, thanx, you phrased that perfectly. I have that same sub-concious operating style. I'm constantly accessing commands using "last years" format, then three keystrokes later I realize I've missed something. As with you, I don't mind the changes that add value, even if we don't use them... it's the "change for the sake of change" that makes every software release feel like we're shooting ourselves in the foot. This particular feature just SCREAMS "change for the sake of...." I'll stick with the ribbon, as I've gotten used to it, and if I can't turn off the new feature, I'll just have to get used to it.
The root of the problem seems to be the need to put out a new release every year... nothing wrong with that, except AutoDesk seems to feel no one will buy it unless it looks "all-new", and given that purchase decisions are almost universally made by purchasers, rather than by users, they may well be right... and AutoDesk ends up having marketers making decisions about what to develop in the software.
