style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">How
do you modify the hatch scale, if the hatch scale is too large and you can not
select it? I have an assembly and some of the components hatch has no visible
lines to select and thus I can not edit. If I can't select it, how do I change
it?
"AUGUST PANNING" <
href="mailto:APANNING@MESTEK.COM">APANNING@MESTEK.COM> wrote in message
href="news:71E6C3F80555F9201D28445D5699DF58@in.WebX.maYIadrTaRb">news:71E6C3F80555F9201D28445D569......
Edit the sketch which contans the hatch, go
through the motion like you are applying the hatch again, the existing hatch
should pop up in the prompt, edit the scale from there.
<drewp@yahoo.com> wrote in
message
href="news:f190b3a.-1@WebX.maYIadrTaRb">news:f190b3a.-1@WebX.maYIadrTaRb...
not select it? I have an assembly and some of the components hatch has no
visible lines to select and thus I can not edit. If I can't select it, how
do I change it?
"Chris" <
href="mailto:chrisc@alumni.ucsd.edu">chrisc@alumni.ucsd.edu> wrote in
message
href="news:0DA5229D9EF81AC4C678D7693AE0B378@in.WebX.maYIadrTaRb">news:0DA5229D9EF81AC4C678D7693AE......
Still not sure what "Sketch contains the hatch"
you mentioned here ? The Sketch in the Browser?
"AUGUST PANNING" <
message
href="news:71E6C3F80555F9201D28445D5699DF58@in.WebX.maYIadrTaRb">news:71E6C3F80555F9201D28445D5......
go through the motion like you are applying the hatch again, the existing
hatch should pop up in the prompt, edit the scale from there.
message
do I change it?
"AUGUST PANNING" <
href="news:F105F963FD8387458898B78DB1770BB4@in.WebX.maYIadrTaRb">news:F105F963FD8387458898B78DB17......
I was assuming the question was about a hatch
applied in a sketch. Looking back at the original post closer, I am not sure
what a component hatch is.
"Chris" <
message
href="news:0DA5229D9EF81AC4C678D7693AE0B378@in.WebX.maYIadrTaRb">news:0DA5229D9EF81AC4C678D7693......
"AUGUST PANNING" <
message
href="news:71E6C3F80555F9201D28445D5699DF58@in.WebX.maYIadrTaRb">news:71E6C3F80555F9201D28445......
message
can not select it? I have an assembly and some of the components hatch
has no visible lines to select and thus I can not edit. If I can't
it?
