Inventor General Discussion
nicu_bogd
Message 1 of 2 (120 Views)
hatch and sheets
120 Views, 1 Replies
11-13-2013 11:59 AM
Hello. Using ISO.idw template I created into a sheet a Sketch which contains a hatch. Now I want to delete that hatch and I don't find anywhere how to delete it.
The second problem is this: I want to create in multiple sheets the same drawing but with small differences. How to copy a drawing from a sheet to another sheet. I press right click on the first sheet and i press Copy but there's no Paste button.
Product Support
inchul.lee
Message 2 of 2 (95 Views)
Re: hatch and sheets
11-15-2013 06:10 AM in reply to: nicu_bogd
Hi nicu_bogd,
If you want to remove a hatch,
  1. Edit a sketch that contains the hatch.
  2. Click Fill/Hatch Region and select the hatch.
  3. Disable Hatch.
You can't copy sheets within a drawing. Please follow these steps,
  1. Create a new drawing.
  2. Go to the source drawing.
  3. Shift-select or Control-select the sheets you want, then copy.
  4. Go back to the new drawing.
  5. Paste.
You can still copy Views within a drawing.
I hope the above answers your question.
Thanks.
Inchul Lee
