Inventor Forum
Hard Part- Help Experts
17 REPLIES 17
Message 1 of 18
bespel
575 Views, 17 Replies
Hi to all,
i have problem with this.
I have no more infos but the attached drawing.
I have attached too the part until the level i have reached with all my force.
Thank in advance for the help.
17 REPLIES 17
Message 2 of 18
salariua
in reply to: bespel
I am no expert but the 4.03 dimension seems wrong (ADS1 file attached) and I think it should be 3.992 (ADS2 file attached)
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 3 of 18
bespel
in reply to: salariua
Hi Adrian,
you are very kind. Thank you for your help.
I was going mad trying with sheet metal... with no success.
Thank you!  The wrong dimension... i don't know..probably you are right!
Thank you again!
Bes
Message 4 of 18
bespel
in reply to: bespel
Hi Adrian,
what are the consideration that make you  think that there is an error and that it's better that other number?
Just to learn 🙂
Message 5 of 18
salariua
in reply to: bespel
the 4.03 dimension makes the coil sit wrong. Point one is not on face and point two not coincident with exit edge. That's why I have the delete face operation at the end of ADS1 file.
If you delete the dimension and constraint point one on face edge you end up wit 3.992 but I am no expert.
Adrian S.
blog.ads-sol.com
Message 6 of 18
bespel
thank you Adrian!
Message 7 of 18
IgorMir
in reply to: bespel
Hi Bespel,
Here is what I can offer. IV 2010 fiile. End tips need some more work on it but overall it should give you some ideas.
Cheers,
Igor.
Web: www.meqc.com.au
Message 8 of 18
JDMather
in reply to: bespel
Looks like the actual geometry is the typical cylindrical cam problem posted here many times over the years.
To model correctly - you have to consider the actual manufacturing process.
Can you provide information on your manufacturing process?
I am going to assume this is not from rolled sheet welded to the hub, (but if it is - you should let us know).
.....well I was going to continue... but decided I need to know answer to above question.
Message 9 of 18
IgorMir
in reply to: JDMather
Hi JD
I couldn't see any sheet metal part in the sketch provided by OP. It looks like the machined part all together. While we are on the topic - in the model I have provided I couldn't get the Sweep to do a clean cut at the tip. It leaves a small step over there. Seems like Sweep doesn't want to follow the Rail properly. Or am I missing something obvious here?
Igor.
Message 10 of 18
JDMather
in reply to: IgorMir
@IgorMir wrote:
Hi JD
Igor.
That is what I see in the drawing as well.  But I am thinking the drawing might be a simplification of the actual part - based on some very similar designs I made more than 20 years ago when I was still working out on the shop floor.  I will go ahead and proceed as though it was totally machined from bar stock.
Message 11 of 18
JDMather
Hopefully this is going to make some sense.
First, I think the supplied drawing is an approximation on some of the dimensions based on old 2D drawing techniques and hand measurements rather than geometry.
Second, I think the true profile depends on the manufacturing process as I will try to demonstrate.
I am going to assume the true profile is a Helix cut with the side of a Ø5mm end mill (and then perhap ground finished).
The motion of the cutter is essentially a cylindrical cam follower - the cut profile is dependent on the follower diameter (the end mill in this case).
With Sketch2 visible - examine the 2 sketch points from the Right side view - I think these are approximations in the drawing.
Hide Sketch2.
Unsuppress Thicken1 - the surface representing the centerline path of a Ø5mm cutter.  Now this could be moved, but the point to observe - is that the actual cut profile will be dependent on the cutter diameter, whatever the position of the centerline of travel.
At least that is the way I see it.
Message 12 of 18
bespel
Hi, it is machined from bar. I don't know much but this.
Your points are very interesting and correct, thank you for your help, your time, the parts you have modelled  and your experience.
Thank you all.
Now i will study your solutions!
Message 13 of 18
JDMather
in reply to: bespel
I just realized that I had one of the dimensions as Ø30 where it was supposed to be Ø32.
Message 14 of 18
bespel
Thank you for the accuracy!
Message 15 of 18
IgorMir
in reply to: bespel
Ni Bespel,
Here is an updated part with the end tips fixed.  There was a small problem with the Sketch6 for the Sweep1.
Cheers,
Igor.
Message 16 of 18
rmerlob
I've always thought that we should be able to parametrically sketch directly on curved surfaces, at least cilinders. Something along the lines as a 3D sketch where all lines and points are constrained to a surface.
Or is that too much to ask to any CAD software?
Anyways i'll give it a try and see what i come up with.
Message 17 of 18
JDMather
in reply to: rmerlob
Like 3D sketch Equation Curves?
Message 18 of 18
rmerlob
No what I had in mind is more like drawing a line/circle/spline in the 3D sketch enviroment but when you click the points it actually projects them through the view and onto the surface.
In this mode of course when you pick two points for a line instead of an actual line you would be drawing a spiral, I know you can do this with other commands but what I have in mind is something a bit more intuitive that actually feels like drawing on a rolled sheet of paper or something like that.
