Inventor Forum
HALF SECTION VIEW IN .IAM WON'T SHOW UP IN THE .IDW
7 REPLIES 7
Message 1 of 8
292 Views, 7 Replies
In the .iam file, I created a "half section view" and saved it as a design
view.
Can the "half section view" be shown in the .idw file ???
Thanks.
IV 7 sp1
Dell Workstation PWS 360
Windows XP Pro sp1
Pentium 4 - 3.0 GHz & 1.5GB of RAM
NVIDIA Quadro FX 1000 - 6.14.10.4523
18 x 20 dual UltraSharp Monitors
7 REPLIES 7
Message 2 of 8
No, the design view does not retain this information. You will need to
create a section view in the IDW.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Calimesa" wrote in message
news:A2F6552C5F8A8B076F8140B12000430B@in.WebX.maYIadrTaRb...
design
> view.
> Thanks.
> IV 7 sp1
> Windows XP Pro sp1
Message 3 of 8
The reason I don't want to create a section view in .idw 'cause the .iam
including 4 springs and it'll take forever to do that. I don't want the
detail the but to show the springs in the isometric view.
Just thought I could do a short cut but it can't, huh ...
"Sean Dotson" wrote in message
news:242A9BBF3D9D01C44BFC89199E3FFCEC@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> design
> > view.
> > Thanks.
> > IV 7 sp1
> > Windows XP Pro sp1
Message 4 of 8
You can mark parts such that they will not appear in section views in IDWs.
Do a bit of searching on the NG and you'll find out how to do this. This
was the springs won;t be shown in the section.
Sean Dotson, PE
news:03E89527AD23DE0C6DF0A166703632FF@in.WebX.maYIadrTaRb...
> > Sean Dotson, PE
> > design
> > > view.
> > > Thanks.
> > > IV 7 sp1
> > > Windows XP Pro sp1
Message 5 of 8
You should be able to create a design view that has the visibility of the
four springs turned off and then create your section from that view.
Message 6 of 8
Sorry to mislead you guys. Here is what I want:
I have a housing with 4 springs inside. I want to show in .idw a half
section view of the housing and 4 springs in the ISOMETRIC view WITHOUT
creating a proj. section view.
"Gary R Smith (Autodesk)" wrote in message
news:6E882D2166B6363B195362513541309B@in.WebX.maYIadrTaRb...
Message 7 of 8
That's the only way to do it AFAIK
Sean Dotson, PE
news:9174B058B3EEA6F79273385CBBA2BCCA@in.WebX.maYIadrTaRb...
the
Message 8 of 8
Chris - in the Browser: in the view you'll eventually make the half section
view from RMB and choose 'Show Contents', then find your springs in the assy
tree and RMB uncheck 'Section'. Then it won't be as slow - I think.
HTH
Peer
