Mark,
Some of what you want can be done without programming, and all of what you want could be accomplished with a VBA program.
The numeric properties associated with the active sheet metal style (Thickness, BendRadius, and so on) are exposed as parameter values in the sheet metal part. You can export these parameters (export parameter checkbox) as custom properties and then recover these custom model parameters in the drawing title block (see attached image).
The IV object model exposes an ActiveSheetMetalStyle object that contains all information about the sheet metal style (including name, material, and so on).
So it is not as easy as it might be, but you can get there from here.
HTH
Neil
"Mark Zimmerle" wrote in message news:40718da2_3@newsprd01...
Mike,
This is a "useable" work around, but I would like to (as Kathy made mention) have access to the parameter "ACTIVE STYLE", since this contains the THICKNESS and MATERIAL, as well as other parameters related to the specific Sheet Metal Style. I cannot 'get to' the Active Style.
What I would like to do is to pass the parameters into a Drawing Title Block. If I change the material or SM Style, I do not want to have to remember to go and change tow or three or four ... other parameters / fields. I thought that software was a tool that made one's job easier. Am I wrong? I also thought that a computer allowed for faster editing than the more 'traditional' method of editing "by hand". It is starting to sound like AD doesn't want that param touched. Please correct if I am of base here.
TIA
Mark Zimmerle
"Mike Maenpaa" wrote in message news:40717dac_1@newsprd01...
In your IPT, create a new Material that has the same name as your sheet metal style.
In your IDW, add a property to your title block that pulls the material from the IPT.
Mike
"Mark Zimmerle" wrote in message news:407169de_2@newsprd01...
Gurus,
I have a question regarding the parameters that are used in the sheet metal mode of IV. Can I access the "Active Style" for use in the BOM, TB, and other extraction aspects? If so, how can I tie this into, let's say the Title Block?
TIA
Mark Zimmerle
