What tools do i need to use to form the valve body?
I want to make the attempt so some guidance on how to start and which tools
It will be a solid part
Best Regards
Harry
This will require most of the tools in your toolbox.
Attach your attempts here as you go for suggestions and instructions.
Tip 1: Forget the easy features - concentrate on the difficult features first.
Pretty much every tool like JD said. (Except for tube and pipe along with frame generator)
I would start with the exterior first doing fillets last. Then work to the interior core along with the flange holes save for pretty much the last feature.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
@Cadmanto wrote:
....I would start with the exterior first doing fillets last. Then work to the interior core....
I was thinking I might do just the opposite.
Model the "missing" interior core as a solid body that I would later Combine-Subract from the main part.
One thing for sure - this isn't a beginner part. (or actually, assembly)
Frankly, based on the most recent posts by the OP, I think this one might be just a bit too advanced for now.
But hey, give it a go and let's see what happens.
I attempted the top section of the valve.I can see a issue around the neck but i post my first attempt.Do i need to use different tools?
thanks
Harry
Here's been a similar task:
http://forums.autodesk.com/t5/Inventor-General/Loft-or-not-to-Loft/td-p/4949098
Walter
Walter Holzwarth
wh,thank you
i think the shape i want is different in that it is more compact up the top section.
Is it possible to use this picture attached to get the shape?
thanks for help
IMO this is no easy task, and only one 2D view normally is not enough.
I've tried to get an impression of the outer faces, and I think, I'm rather near to the section view. But as can be seen, lot's of features were needed.
In the end, I tried to place a surface fillet between the red and blue faces, but no luck. And suddenly, duplicate faces showed up and couldn't be deleted.
😉 My impression: Another task for Autodesk.
Walter
For better visibility, main color should be switched from Yellow (Clear) to Yellow (Dark) or similar
Walter Holzwarth
Hi
wh
thanks for taking time to attempt.Looks like a difficult part.Maybe a difficult part for Inventor
Thanks again
I don't think, that it's too difficult for Inventor.
Sometimes the problem is placed on a chair. See my 2nd attempt.
Walter
Walter Holzwarth
