Inventor Forum
GRP mechanical properties
4 REPLIES 4
richiesuk
2261 Views, 4 Replies
can you tell me what should I put in the material style for GRP because I can find much more info on some sites and I am not sure what strength should I use.
(in the actual datasheet for the grp I uset here are tensile strength (long and transverse as well), Tensile modulus (l and t)m compressive Strength (l & t), Compressive Modulus (s & t), shear strength (l&t), flexular strength (l&t) and flexular modulus (l&t) and Poissons Ratio (l & t).
So I am a bit confused....
many thanks,
Richard K.
4 REPLIES 4
in reply to: richiesuk
Glass Reinforced Plastics, like all Fibre Reinforced Plastics, are
anisotropic materials. That's the fancy word for them having properties
that usually differ significantly along each of the primary axes.
Other than using the specific gravity (density) to calculate the mass,
Inventor doesn't use the mechanical properties, so you can fill in whatever
you want.
From what I can see, and I hope someone proves me wrong, the FEA which comes
with IV Simulation and, I presume, Pro -only deals with isotropic
(properties are considered to be equal in all directions) materials. It has
no place to accept properties that differ from one principal axis to
another.
Richard
wrote in message news:6308791@discussion.autodesk.com...
I use.
many thanks,
Richard K.
Anthony
Inventor has GFRP (Glass Fibre Reinforced Plastic) which may be of some use to you, I'm not well up on the physics of the materials so don't know how similar it is to GRP.
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
sam_m
in reply to: Anthony
do you realize the question was asked 2.5 years ago?  (I'm guessing Richard is no longer expecting/waiting for an answer here...)
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Anthony
in reply to: sam_m
Sorry didn't spot the date on the post Smiley Surprised
