Inventor Forum
Ground all parts in an assembly
19 REPLIES 19
Message 1 of 20
LloydBrewer
5198 Views, 19 Replies
Hi all,
I have been provided with an assembly, containing sub-assemblies, by a sub-contractor. This assembly was originally created using Solidworks and then converted for use with Inventor (I don't know how and cannot request original files). As such the assembly is unconstrained and not grounded. I want to ground everything before having to alter the location of some valves.
Is there a way of grounding all parts, including those in sub-assemblies, from the top level assembly? Or do I have to open each sub-assembly and ground the associated parts from there?
Thanks in advance.
Tags (2)
19 REPLIES 19
Message 2 of 20
CCarreiras
in reply to: LloydBrewer
Hi!
You have to go to each one to ground the components (parts and sub-assemblys).
The good news is, the parts within the subassemblys only move when you're inside the sub-assembly not in the main assembly (Unless this sub-assembly has "Flexible" Status ON), so you can ground the sub-assembly's parts in the same time you need to edit them.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 3 of 20
Window select all the components, assemblies, sub-assemblies, etc.. Right Click and select Grounded.  You may have to repeat this twice.
Message 4 of 20
LloydBrewer
in reply to: CCarreiras
Thanks for the response. I thought this might be the case but was hoping for a quicker way to ground everything at once. Oh well.
Regards
Lloyd
Message 5 of 20
blair
In the Brower Window, you can select the first items, then hold down the "Shift" key and then select the last item. This will select all the items between the two selected items.
Delta Tau Chi ΔΤΧ
Message 6 of 20
Hi LloydBrewer,
I use a simple iLogic rule to do this. You can find this rule at this link:
http://inventortrenches.blogspot.com/2012/05/working-with-unconstrained-imported.html
If you've not used iLogic before, here are a couple of links to get you started:
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
http://autodeskmfg.typepad.com/blog/2012/01/working-with-external-ilogic-rules.html
I hope this helps.
Curtis
Message 7 of 20
Hi Curtis_Waguespack,
Thanks for the links. The iLogic rule worked perfectly. I've been meaning to read up on iLogic for a while, maybe this will be the prod I need!
Many thanks
Lloyd
Message 8 of 20
Necro post - but here's a routine that will recursively loop through ALL subassemblies and ground EVERYTHING
Sub main
	userResponse = MsgBox("This will ground ALL parts & subassemblies in ALL" & vbCrLf & _
		"parts and subassemblies in this assembly, are you sure you want to continue?" & vbCrLf & _
		"ALL FILES MUST BE CHECKED OUT", vbYesNo, "Ground Everything")
	If userResponse = 1 Or userResponse = 6 Then 'Ok, or Yes
	    'ground parts in this file, begin recursion
		sDefLoop(ThisDoc.Document)
		RuleParametersOutput()
		iLogicVb.UpdateWhenDone = True
		ThisDoc.Document.Update
	End If
End Sub
Sub sDefLoop(oCurrentDoc As Document)
	Dim oAsmDoc As AssemblyDocument
	Dim oOcc As ComponentOccurrence
	'Select based on file type, this exists to cast to the correct object type before calling the appropriate sub program
	Select Case oCurrentDoc.DocumentType
        Case DocumentTypeEnum.kAssemblyDocumentObject 'it's an assembly file
			oAsmDoc = oCurrentDoc
			oAsmDoc.ComponentDefinition.RepresentationsManager.LevelOfDetailRepresentations.Item("Master").activate 'activate master LoD
			For Each oOcc In oAsmDoc.ComponentDefinition.Occurrences 'loop through all of occurrences in this assembly file
				 If Not TypeOf oOcc.Definition Is VirtualComponentDefinition Then oOcc.Grounded = True 'if it's a real part, ground it
			Next
			For Each oDoc In oAsmDoc.AllReferencedDocuments 'loop through all of the sub-assemblies, this is recursive
				sDefLoop(oDoc)
			Next
		Case Else
			Exit Sub 'if it's not an assembly, what are you even going to do?
	End Select
End Sub
Message 9 of 20
I use this kind of short formula for foreign STEP models and it works fine:
Sub Main()
    oDoc = ThisDoc.Document
    For Each oOcc In oDoc.ComponentDefinition.Occurrences
        SubGroundedOn(oOcc)
    Next
End Sub
Sub SubGroundedOn(oToGrounded)
    oToGrounded.Grounded = True
    For Each oOccSub In oToGrounded.SubOccurrences
        SubGroundedOn(oOccSub)
    Next
End Sub
If have virtual components or something I guess you will just have to use Catch Try between the SubGroundedOn(oOccSub)?
Message 10 of 20
Hi @Curtis_Waguespack
Could you edit the iLogic rule so it can Un-block all existing components?
Appreciate your help.
Radu
Message 11 of 20
@RStancescu,  I'm not sure I understand the request.
Can you provide a bit more detail about how you'd like it to work?
If so I can likely update it to your needs.
I hope this helps.
Curtis
Message 12 of 20
Thank you for answering.
After I open an assembly, would like to run a rule or click a button that will un-ground all the grounded parts in the iam; eventually telling me that there are 200 grounded parts. (like a warning)
Or, after running the rule, to automatically select all the grounded components; and then I can manually right click and un-ground them.
Appreciate your support.
Radu
Message 13 of 20
Thank you for answering, @Curtis_Waguespack
Radu
Message 14 of 20
Hi @RStancescu ,
See this example.
I hope this helps.
Curtis
Sub Main
	oOccs = ThisDoc.Document.ComponentDefinition.Occurrences
	count = oOccs.count
	If count > 100 Then
		sMsg = "Whoa there cowboy!" & vbLf _
		& "There are " & count & " components in this here assembly." & vbLf _
		& "This could take a little while, are you sure you want to pull that trigger? ."
		oInput = MessageBox.Show(sMsg, "iLogic", MessageBoxButtons.YesNo)
		If oInput = vbNo Then
			Exit Sub
		End If
	End If
	Call TraverseAssembly(ThisDoc.Document.ComponentDefinition.Occurrences)
End Sub
Function TraverseAssembly(oOccs As ComponentOccurrences)
	For Each oOcc In oOccs
		oOcc.Grounded = False
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			Call TraverseAssembly(oOcc.Definition.Document.ComponentDefinition.Occurrences)
		End If
	Next
End Function
Message 15 of 20
Thank you for your code. @Curtis_Waguespack
It works fine if there is no pattern in the assembly.
With a pattern, I get the attached notification when running the rule. Could you please look at it?
After closing the error, everything is good, no grounded components.
Thank you.
Radu
Message 16 of 20
doh! 😬
It's always the patterns that are the trouble makers. 🙄
Give this version a try. It will catch the error when a pattern is encountered, and move on.
I hope this helps.
Curtis
Sub Main
	count = oOccs.count
	If count > 100 Then
			Exit Sub
		End If
	End If
End Sub
		Try : oOcc.Grounded = False: Catch : End Try
		End If
	Next
End Function
Message 17 of 20
Thank you @Curtis_Waguespack
That works great! I copied the other rule two so now my users have all the choices.
Appreciate your support and let me know if you need any help.
Radu
Message 18 of 20
Hi @RStancescu
If you want to give your users an option to ground or unground, you could use this version.
Note too that this version grounds/ungrounds the components in subassemblies too.
Sub Main
	oInput = InputRadioBox("Select one", "Ground All", "Unground All", True,"iLogic")
	Call TraverseAssembly(ThisDoc.Document.ComponentDefinition.Occurrences, oInput)
End Sub
Function TraverseAssembly(oOccs As ComponentOccurrences, oInput As Boolean)
		Try : oOcc.Grounded = oInput : Catch : End Try
			Call TraverseAssembly(oOcc.SubOccurrences, oInput)
		End If
	Next
End Function
Message 19 of 20
@Curtis_Waguespack
That is cool!
I was ready to present to my users two rules but this last one is better.
Great work and appreciate your work!
Radu
Message 20 of 20
P_Korgaonkar
Thanks. This code works.
How many levels will it go down to?
Will it reach all sub-levels?
Regards
Parag
